Connecting two modules
I have a problem (I think because I´m a beginner in Verilog).
I want to connect a module (baseband_wrapper) with a PIO (TIC_generator). Therefor I created an output called "ticirq" in baseband_wrapper. You can see this in baseband_wrapper.v.
Now I have to connect this output with the input of the PIO. How does this work?
I tried to make a conduit in SOPC-Builder and then to connect the two modules in the top-level-file: .in_port_to_the_TIC_generator(ticirq_from_the_gps_L1_0)
But then there occurs a problem: <<Error: Port "ticirq" does not exist in macrofunction "gps_l1_0">>
Although everything seems to be ok in gps_L1_0.v
Is there another way to connect these two modules or is there a mistake in the code? Or am I on the wrong path at all?
Thanks for your replies.
