17261 Discussions
Constraining MII Interface (Input/Output Delay)
skyjuice88
While I know how to constraint regular I/O delays (set_input_delay min/max and set_output_delay min/max), when it comes to MII-related timing I am a bit confused.
The datasheet of the PHYs have the following timing specs.
RXDV, RXD, RXCLK and TXCLK are inputs to the design, while TXEN and TXD are outputs of the designs.
How exactly should I constrain the timing constraints correctly?
Nurina
Thank you for using Intel Communities. Please allow some time while I investigate your problem.
Nurina
Nurina
May I know which device you are targeting?
Nurina
Nurina
Also, which PHY are you using?
skyjuice88
I am using Microchip LAN8710 (Timing diagram on page 73 https://ww1.microchip.com/downloads/en/DeviceDoc/8710a.pdf) to interface on my Arria 10 devices.
Nurina
Thanks, and which Quartus version are you using?
Nurina
skyjuice88
I am using Quartus Pro 22.4
Nurina
Sorry for the late response.
Clocks:
Add create_clock for both RX and TX clocks to input port.
RX signals:
set_input_delay -clock MII_RXCLK -max 28.0 [get_ports {RXDV RXD*}] -add_delay
set_input_delay -clock MII_RXCLK -min 12.0 [get_ports {RXDV RXD*}] -add_delay
TX signals.
set_output_delay -clock MII_TXCLK -max 12.0 [get_ports {TXEN TXD*}] -add_delay
set_output_delay -clock MII_TXCLK -min 0 [get_ports {TXEN TXD*}] -add_delay
Nurina
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Nurina
May I know if above solution helped?
Nurina
