17255 Discussions
Converting POF file to SVF file
Clay
Hello Team,
I have a POF file for programming MAX 10 IC(10M04SCU169A7G).
We need SVF file to do in-system programming .
I tried to use Quartus II 15.0 Programmer to convert POF file.
But I check in-system programming(IEEE1532) result , nothing wrong in programming but fail in verifying.
To make sure the POF file is correct , I use Usb blaster to perform programming , all pass and the product is working well.
It means that there is no issue with the POF file
I suspect the SVF file I converted is not correct.
Is there other way to convert it to SVF file?
Vicky1
“We need SVF file to do in-system programming .”
For in System Programming refer the “In-System Programming” from the following configuration user guide,
https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/hb/max-10/ug_m10_config.pdf
Are you using Third-party programming tool?
.jam, .jbc, or .svf file these are third party programming files.
This might help you,
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
