17267 Discussions
Create CvP Files option in Programmer
GlennF
I have an Arria 10 .sof file which was created in Quartus Prime 17.0 Standard with the CvP Settings enabled.  I also have a .cof file which I normally use with Convert Programming Files in Programmer to split the .sof file into .jic and .rbf files.  So the .cof file enables the Create CvP Files option in Programmer.  What does Programmer do if I open the .cof file and manually uncheck Create CvP Files?  Should it create a .jic that includes both the I/O and all the internal logic?  Or does it just skip the .rbf and create the same .jic file that it would create if I left Create CvP Files enabled?
Thanks very much,
GlennF
YuanLi_S_Intel
By right it should follows the setting in COF.
