Custom Processor CusP
Where is documentation to the sources file of cusp (cusp-engine-tests.jar\src\... ).
i don't think its public, what are you trying to do?
It's not documented for a reason..... hint you don't want to be poking around in there.
Because CusP is a better tool than SoPC and Qsys.
how did you arrive at that conclusion? if you look around the forum you'll find that cusp isn't supported and that Altera is porting cusp IP to HDL
CusP and SOPC Builder/Qsys have different purposes so it's a bit odd to even compare them. CusP is only on the ACDS for legacy reasons, it is not being maintained so I wouldn't recommend using it.
But Quartus recognizes CusP component and compiles.
CusP component is working, I tested on DE0 Nano.
example: cusp_test4.c
# include <alt_cusp.h>
SC_MODULE(cusp_test4)
ALT_GPO<sc_bv<8>> led;
void behaviour()
int state = 0;
while(1)
for (state = 0; state <= 0xfff; state++) {
if (state == 0x1fff)
led.write(1);
else if (state == 0x3ff)
led.write(2);
else if (state == 0x5ff)
led.write(4);
else if (state == 0x7ff)
led.write(8);
else if (state == 0x9ff)
led.write(16);
else if (state == 0xbff)
led.write(32);
else if (state == 0xdff)
led.write(64);
else if (state == 0xfff)
led.write(128);
SC_CTOR(cusp_test4)
SC_THREAD(behaviour);
Use at your own risk then (no support, documentation, etc..) It's typically not a good idea to rely on unsupported features especially when the vendor is moving away from those same features.
Documentation is not needed, I compiled a new "CusP (no_lic)", everything is in the "cusp-engine-tests.jar". Altera make the mistake of not doing support for "CusP".
Full circle to my first post, there is a reason why it's not documented or supported.... It was experimental and wasn't persuded any further. I wouldn't recommend using for production since who knows how long it'll work for (or if it will even remain in the tools).
I have a question, also for Altera, if there is no documentation and support it would be possible to share this on open-source license.
Since CusP isn't open source licensed I wouldn't attempt to do so. The HDL output from the tool you can make available.
Not what I meant.
"Altera" there is no documentation and support for users.
Does the "Altera" may provide the source code and documentation on the open-source license.
Since it was internally developed and never offered as a product the answer is no it cannot be offered under an open source license. You can try asking your FAE to see if they can make a request but I don't think you'll get a different answer.
if you're interested in open source, have you thought about trying or contributing to myHDL?
Please give me an email to FAE.
To write simple programs, only need to me a verilog or vhdl.
To write something more difficult, is needed a "hardware accelerator", "myHDL"is not suitable.
I am currently writing a "Cellular Neural Networks (CNN)" program in the "CusP".
It turns out that, I do not have adequate competence to ask such questions on "CusP" and "eperl.exe" error (the human factor). This means that I know how to decode the files "*.epl (generate_rtl.epl) ". Maybe if I wrote on the forum how to do it, someone from Altera to finally talk to me.
Hi.
I am new user on this forum, and not very spike to english, I am polish.
To "goeth": I would like to know about the cusp.
Wi&#281;c pogadamy po polsku, bo w sumie ja te&#380; dobrze nie znam angielskiego.
Pewnie chcia&#322;by&#347; si&#281; czego&#347; dowiedzie&#263; na temat programu "cusp" to skrót od Custom Processor czyli ten program z komponentu opisanego w j&#281;zyku SystemC generuje ten komponent w j&#281;zykach vhdl lub verilog w archtekturze tak zwanej ASIP (Application Specific Instruction set Processor) w pisz w google to co w nawiasie to co&#347; znajdziesz na temat tej architektury. A konkretnie dokumentacji odno&#347;nie tego programu to nie znalaz&#322;em ale znalaz&#322;em dwie publikacje s&#261; w za&#322;&#261;czniku, w j&#281;zyku angielskim. Je&#347;li wolno spyta&#263; to co konkretnie chcesz napisa&#263;.
Kudos for reverse engineering CusP. Yeah you're not going to get anything from Altera on this. But Mentor has a C->Hardware tool that Altera considered using to replace CuSP (Catapult-C I think). Definitely not free though.
