Customized signal
Hello, for my project, i need to generate an input that is customizable. Means that i want to customize the high state and low state. For example, I set 1 sec for high state and 0.5 sec for low state. How can i set this kind of signal from vhdl ? Any ideas ? Thank you in advance.
use a counter to count out 1s and 0.5s. Then toggle.
what do you mean by toggling both counter ?
Use a counter to count out the time. Then set your signal as you want at the appropriate time.
D you have any example ?
signal cnt : unsigned(31 downto 0); process(clk) begin if rising_edge(clk) then cnt <= cnt + 1; if cnt = ONE_S then op <= '1'; elsif cnt = ONE_S_PLUS_0_5s then op <= '0'; end if; end if; end process;
Thank you !
Do I need a loop for this signal to repeat infinitely ?
--- Quote Start ---
signal cnt : unsigned(31 downto 0); process(clk) begin cnt <= cnt + 1; if cnt = ONE_S then op <= '1'; elsif cnt = ONE_S_PLUS_0_5s then op <= '0'; end if; end process;
--- Quote End ---
Tricky, I am a bit disappointed...no clocking this time
--- Quote Start ---
--- Quote End ---
No, it is a continuous logic by itself but you need to add clock edge and your counter will keep going for ever.
--- Quote Start ---
--- Quote End ---
Doh - fixed it.
