Hi All,
I'm working with Cyclone 10 GX, which has a reference clock of 100MHz .
What lowest frequency could I reach with PLLs using this clock as a reference clock?
I've tried to play with Fractional and Integer PLLs and the lowest frequency I succeeded to reach was 3MHz. Is it possible to reach lower frequencies?
How can I set cascading of the PLLs?
Thank you!
minimal output frequency is definer bei VCO frequency range and output divider factor. It's about 0.6 MHz. Lower frequencies can be achieved with frequency divider in core logic.
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
