17116 Discussions
Cyclone IV EP4CE10F17C8N Chip: Light LED
Hello All,
This is my first time using an FPGA, my independent research is currently using the book "RTL Hardware Design Using VHDL" by Pong Chu.
I have purchased an Altera Cyclone IV with a EP4CE10F17C8N chip. I am programming using Quartis Prime Lite, in VHDL. I am programing the board with a USB Blaster, all drivers installed.
My aim was to test a simple code by turning on an on-board LED. I do not see anything wrong with the VHDL Code and I have no compilation error, yet I do not see any LED turned on (aside from the power LED). This leads me to belive it may be the pin assignment.
I am using the following data sheet:
https://www.waveshare.com/w/upload/c/c8/coreep4ce10-schematic.pdf
(https://www.waveshare.com/w/upload/c/c8/coreep4ce10-schematic.pdf
And assigned LED to PIN_D12
My Code is as follows:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; ENTITY light IS PORT(--X1 : IN STD_LOGIC; LED : OUT STD_LOGIC := '0' ); END light; ARCHITECTURE LogicFunction OF light IS BEGIN LED <= '1'; END LogicFunction;
I am not sure why I can not light the LED, any help will be much appreciated. Thank you in advance!
From schematic LED will turn on when you assign LED <= '0' and will turn of when LED <= '1'.
Yes, the LED is active low.
--- Quote Start ---
--- Quote End ---
Got it, thank you all! So I was able to light the LED knowing it is active LOW. I.e. I changed LED <= '1'; to a 0.
Thanks again!
