I am attempting to use DCFIFO megafunction in my design, but two problems met: 1. the rdempty signal always keep high, and rdusew signals don't function, too. so I can't read data from FIFO. after checking the wrempty and wrusew signals, they function correctly, so I use wrusew to detect and correctly got the desired. 2.even when use wrempty or wrusew signal, the reading data is not exactly the same as what I wrote if rdclock is different from wrclock. following is my verilog codes: innerFIFO innerFIFO_inst ( .aclr ( innerFIFO_clear ), .data ( innerFIFO_datain ), .rdclk ( innerFIFO_rdclk ), .rdreq ( innerFIFO_rdreq ), .wrclk ( innerFIFO_wrclk ), .wrreq ( innerFIFO_wrreq ), .q ( innerFIFO_dataout ), .rdempty ( innerFIFO_rdempty ), .rdusedw ( innerFIFO_rdusedw ), .wrempty ( innerFIFO_wrempty ), .wrusedw ( innerFIFO_wrusedw ), .wrfull ( innerFIFO_wrfull ) ); // wire innerFIFO_wrfull; wire innerFIFO_wrempty; wire innerFIFO_rdempty; reg innerFIFO_clear; reg innerFIFO_rdclk; reg innerFIFO_wrclk; reg innerFIFO_rdreq; reg innerFIFO_wrreq; wire[14:0] innerFIFO_wrusedw; wire[14:0] innerFIFO_rdusedw; reg[15:0] innerFIFO_datain; wire[15:0] innerFIFO_dataout; always @(posedge Wr_clock) //line 26 for FIFO reading // always @(posedge rd_clock) replace line 26 with this line, wrong readings when rd_clock is a little bit faster or slower // readings are correct only when both reading and writing clocks are exactly the same begin case(USBwriting_state) USBwriting_ready: begin if (USBnofull ) begin innerFIFO_clear<=0; innerFIFO_wrreq<=1'b1; innerFIFO_rdreq<=1'b1; if(innerFIFO_wrusedw>4)//line 46 // if(!innerFIFO_wrempty) replace line 46 with this line, works // if(!innerFIFO_rdempty) replace line 46 with this line, not work, // rdempty keeps high no change // if(innerFIFO_rdusedw>4) replace line 46 with this line, not work begin innerFIFO_rdclk <= 1'b1; USBfifo[15:0]<= innerFIFO_dataout[15:0]; USBwriting_state<=USBwriting_write; end end else begin USBwriting_state<=USBwriting_full; end end // end of writing_ready USBwriting_write: begin innerFIFO_rdclk <= 1'b0; USBwriting_state<=USBwriting_ready; if (USBnoempty) begin USBfifo<=16'bz; end end USBwriting_full: begin if (USBnoempty) begin USBfifo<=16'bz; end USBwriting_state<=USBwriting_ready; end default: begin USBwriting_state<=USBwriting_ready; end endcase end always @(posedge Wr_clock) //FIFO writing begin case(FIFOwriting_state) FIFOwriting_ready: begin if (!innerFIFO_wrfull) begin innerFIFO_wrclk <= 1'b0; innerFIFO_datain[15:0]<= ADCIdata; FIFOwriting_state<=FIFOwriting_write; end else begin FIFOwriting_state<=FIFOwriting_full; end end FIFOwriting_write: begin innerFIFO_wrclk <=1'b1; FIFOwriting_state<=FIFOwriting_ready; end FIFOwriting_full: begin if (!innerFIFO_wrfull) begin FIFOwriting_state<=FIFOwriting_ready; end end default: begin FIFOwriting_state<=FIFOwriting_ready; end endcase end // ThanksLink Copied
Debug individual blocks so you can find the mistake. Understand the timing diagram from the https://www.altera.com/en_us/pdfs/literature/ug/archives/ug-fifo-15.1.pdf and try to compare with your code. Can you attach .v file. Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
