17105 Discussions
DDR interface for D/A converter
I need a DDR interface for connecting a high speed DAC (DAC1627 from IDT/NXP). One of the DAC's two's channels gets it data with the risign edge, the other with the falling edge. I have 16 Bit data and clock, transmitted differential LVDS (one pair for each data and clock).
Is there any IP which could fit or other sample code?
You best use ALtera's ALTDDIO_OUT primitive; a 16-bit wide to drive the data and a 1-bit wide to drive the clock. Connect DataA to the datain_l port and DataB to the datain_h port of the 16-bit wide component. You connect "1" and "0" to the datain_h and datain_l of the 1-bit wide clock driver. So the clock to the DAC nicely arrives edge-aligned with the DDR data.
Hi josyb,
thanks for your answer, great!
