DE2-70 Board Problem
Hi
I use Quartus 8.0 and Nios 8.0.I'm programming DE2-70 board.
when I configured Assignments->Device->Device and pin options->unused pins->As output driving ground,De2-70 board was programming but Nios hello_world example didn't work.
when I configured Assignments->Device->Device and pin options->unused pins->As input tri-stated and send the .sof file with Programmer, all leds except power led and 7-segment displays on DE2-70 board went out the light and didn't work any Nios C code.
What could be the reason of this problem ?
See this thread, apparently there's an error in the pin assingments of the DE270
http://www.alteraforum.com/forum/showthread.php?p=108625&posted=1#post108625
