Hi All,
How can I define the default reports directory in Quartus-II?
Thank you!
By default, Intel Quartus software software saves all project output files in 'output_files' directory under Project directory & if you want to change the location click Assignments > Settings > Compilation Process Settings, and specify the Save project output files in specified directory option(Refer attachment).
Please check the below old thread for your reference,
https://forums.intel.com/s/question/0D50P00003yyOPPSA2/setting-directory-for-working-files?language=en_US
Vicky
Vicky
Have you resolved the issue?
Should I consider that case to be closed?
Vicky
Hi Vicky, Yes you can close this case, I selected your answer as the best, thanks!
