Hey,
Firstly I'd like to mention that I'm a beginner in fpga programming :) I will use a simple example to show exactly what I'd like to know: (It turns out that I'm not allowed to post images or links so I used the Attach Files option) As you can see, when there's a rising edge on clk2, the clk0 hasn't yet changed it's state. What I would like to know is it possible to delay the clk2 signal so that when there's a rising edge on it, the clk0 had already changed. (Using TimeQuest analyzer!!!) I know that it's possible to set an offset to clk2 in the ALTPLL but I wanted to know is it possible to solve this problem TimeQuest Analyzer. I tried to set clock latency and net delay, etc but nothing seemed to work. I guess that I just don't understand everything right :) Hope that someone will help, Thanks in advance!Link Copied
dont go putting clocks through logic. That wont help and the skew will change with temperature and other factors.
Use the delay on the PLL to phase shift a clock to the amount you need.
