16597 Discussions
Design partition: Error (18999): Placement cannot find a legal solution.
Yogesh
I have designed a design partition file and generated .qxp file . After importing that file and declaring the file along with top level codes . I am using post fit - netlist type . preservation level - placement and routing .
After starting compilation , fitter fails giving below error :
Error (170079): Cannot place node <name>of type MLAB cell.
How to solve this error ? Please reply as soon as possible.
AEsqu
Did you try to disable the logic lock region assignments?
Yogesh
Yes, If I disable logic lock regions . Fitter will pass without giving errors.
But , frequency achieved will drop drastically.
I want to retain maximum frequency which I had achieved while creating logic lock region .I have explained the same below:-
Say I have 3 modules:
1) Top module
 2) sub-module A-(achieved freq 150Mhz when compiled separately)
3) sub-module B-(achieved freq 200 Mhz when compiled separately)
After I instantiate sub-modules A and B in top module , I am getting 80Mhz and 110 Mhz from both respectively.
So , I thought if I retain the same fitter placement of module B (applying logic lock and design partitioning) I can get same frequency i.e, around 200 Mhz on the Top module .
Please Note that: Fitter used to behave unusally while merging 624 9x9 multipliers into 208 DSPs (cyclone V device) and used to fail sometimes. So Design partiton/ logic lock is very important for me .
But here ,if I try to retain the routing and placement  netlist , I get the above error .
If I remove logic lock fitter will pass but timing falls drastically.
So, please suggest me how to solve this issue.
Yogesh
if I remove logic lock, fitter will fail sometimes because of high routing congestion. How should I go about solving the problem?
regards,
Yogesh
RichardTanSY_Intel
Sorry for idling for some time, do you still need help on this?
AEsqu
It solved by itlsef but I don't remember how.
Could have been due to quartus settings changed or new quatus version.
This can be closed. Have a nice day.
