17266 讨论
Design template installation failed
Junyong
初学者
1,910 次查看
Hi all,
I'm trying to run Stratix10_PCIeGen3x8_DMA_18_0.
Whenever I tried to run it, it gave an error message "Design template installation failed".
I had no log message for it, so I couldn't go further.
Is there any ways to check the log message or handle with above issue?
标签 (1)
0 项奖励
1 解答
ShengN_Intel
员工
1,885 次查看
The design is version 18.0 based. You have to use version 18.0 Quartus Tool.
Sheng
在原帖中查看解决方案
0 项奖励
2 回复数
ShengN_Intel
员工
1,886 次查看
Sheng
0 项奖励
Junyong
初学者
1,856 次查看
Thank you for reply.
It was effective and works now.
Junyong
0 项奖励
回复
