15883 Discussions
Detected PMBUS error during configuration
SivaKona
Part Number: 1SG280HU2F50E2VG (Stratix 10 GX H -Tile  device)
Quartus Prim Pro Version used for SOF generation: 21.1.0 Build 169
Quartus Prim Pro Version used for SOF programming: 21.1.0 Build 169
Current VID settings :
# VID settings
set_global_assignment -name USE_PWRMGT_SCL SDM_IO14
set_global_assignment -name USE_PWRMGT_SDA SDM_IO11
set_global_assignment -name VID_OPERATION_MODE "PMBUS MASTER"
set_global_assignment -name PWRMGT_BUS_SPEED_MODE "400 KHZ"
set_global_assignment -name PWRMGT_SLAVE_DEVICE_TYPE LTM4677
set_global_assignment -name PWRMGT_SLAVE_DEVICE0_ADDRESS 4F
set_global_assignment -name PWRMGT_SLAVE_DEVICE1_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE2_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE3_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE4_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE5_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE6_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE7_ADDRESS 00
set_global_assignment -name PWRMGT_PAGE_COMMAND_ENABLE ON
set_global_assignment -name PWRMGT_VOLTAGE_OUTPUT_FORMAT "AUTO DISCOVERY"
set_global_assignment -name PWRMGT_TRANSLATED_VOLTAGE_VALUE_UNIT VOLTS
Build flow completes without any Critical Warnings.
Existing Warnings does not seem to be related VID settings in QSF
But when I try programming the SOF on FPGA Part, programmer fails with the Error as shown in attached snapshot.
Siva Kona
SivaKona
Pasted error messages in text format
Error(18950): Device has stopped receiving configuration data
Error(18948): Error message received from device: External hardware access error. (Subcode 0x0032, Info 0x00040000, Location 0x00001800)
Error(22248): Detected a PMBUS error during configuration. Potential errors: VID setting is incorrect in Intel Quartus Prime Project. The target device fails to communicate to smart regulator or PMBUS Master on board.
Error(209012): Operation failed
Siva Kona
NurAiman_M_Intel
Below are the KDB that provided the solution to the error that existed:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base...
Aiman
SivaKona
This behavior was due to defective Part. The SOF file worked when S10 GX device was replaced with another fresh one.
Siva Kona
NurAiman_M_Intel
Thanks for sharing the root cause of this issue.
I will proceed to close this case.
Aiman
