I have attached my code, clock counts up from zero and the switch starts the counter. I can't figure out how to set the KEY[3:0] to set the hours, and minutes. Also can't figure out how to display a separate alarm with the flip of a switch. Can someone help me?
Hey.
You need to make a time setup menu, in which you can use the buttons to adjust the time. In this case, the time counter must be stopped.- Mark as New
