16743 Discussions
Does Quartus generate a "Unused Signal" report for modules that it compiles?
WShep1
New Contributor II
Can Quartus generate a "Unused Signal" report for modules that it compiles?  if so, how is it turned on and/or viewed?
ShengN_Intel
after running synthesis, should see the .syn.rpt being generated check screenshot attahced.
Or in GUI, go to compilation report -> Synthesis -> Warning Messages
compilation report -> Synthesis -> Partition "root_partition" -> Optimization Results -> Register Statistics -> Register Removed During Synthesis
Check screenshot attached.
Sheng
ShengN_Intel
Can check the .syn.rpt in output_files folder under section Warnings for <module_name> and Registers Removed During Synthesis. Will have reasons like Pin "" is stuck at GND or Lost fanout.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
WShep1
New Contributor II
Hi ShengN,
I was not able to locate the *.syn.rpt file in the output directory or anywhere else in an of the other project directories. Does it have another name or is it located somewhere else?
Thanks for your timely reponse.
WShep1
ShengN_Intel
Any further concern or update?
Sheng
ShengN_Intel
Sheng
WShep1
New Contributor II
Thanks for your assitance with this question
