17049 Discussions
Driver trouble on CentOS 6.5
I'm trying to set up a node for OpenCL on FPGA development. I accidentally had my CentOS 6.4 update to 6.5 with 2.6.32-431.5.1.el6.x86_64 and the driver does not seem to work. When I run ./user in /hld/linux64/driver I get the following message:
using /dev/de40
couldn't open the device. did you load the driver?
The driver is loaded (I think? I checked using lsmod), but ./user keeps giving me that message. I also checked and /dev/de40 exists when I try to query the FPGA.
dmesg gives me the following when I manually unload/load the driver:
aclpci_drv: module license 'unspecified' taints kernel. Disabling lock debugging due to kernel taint aclpci_init (666): ---------------------------- aclpci_init (667): Driver version: 13.1.3. aclpci_init (682): pci_register_driver aclpci_init (688): success
I'm using a terasic DE5-NET board. Any help in solving this would be appreciated. Thanks!
This is very strange, I'm getting an errno=6 (no such device or address) when I try to open /dev/de40, but I clearly see it. Am I missing something here?
Can you see your board as a PCIe device with /sbin/lspci? Maybe the board did not come up properly or has no FPGA image.
Can you confirm the exact version of the SDK you're using? 13.1? Which build?
Have you tried removing the driver and reinstalling it?
I was trying to use 13.1.3.178. Did a fresh install of 13.1.3.162 and everything is working perfectly now. Must have botched the patch somehow :/
Thanks for all of your help!
That's great news. Also good to hear the driver works with CentOS 6.5. If you have any further issues please feel free to comment/post on the forum here so that others may benefit. Thanks.
