17255 Discussions
Dual Compressed Image not showing on configuration mode drop down list for MAX10
RRomano001
Quartus Prime Version   18.1.0 Build 625 09/12/2018 SJ Lite Edition
Another user reported this same issue, thread is locked:
Screenshot from 2019-05-02 13:43:55.png
JohnT_Intel
Hi, You are selecting the compact variant device which does not support dual compress image. Please change the device by following the device guideline in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_overview.pdf Figure 1.
sstrell
Which MAX 10 device are you targeting? The smallest ones don't support this.
#iwork4intel
RRomano001
Hi SStrell, I am targeting 04, 08, 16, 25, 50.
128K 592 shown image was 04.
04 to 50 must have dual configuration, changing to large devices just modify the size but don't show as dual configuration.
I am not using 02 I know is a single image by design.
Also 02 has different pinout from 04-25 and also annoying 40 50 have different pinout so cannot migrate between full family.
screenshot for sc50 dual boot and Altera flash Ipcore loaded.
Attached full project, has both single image and PLL configuration issue.
JohnT_Intel
RRomano001
Hi JohnT, I grasped now what is SC , I read thoroughly again document you pointed me to.
Page 6 report difference from compact flash, analog and yes SC just from that are single image.
from table on same page, only 02 seems single image, all other in row are 2 image.
After thinking about page 5 figure 1 part numbering and table 3 I realized table 4 refer to maximum size 0x dependent.
SC if I understood are all single image regardless of LE size.
Thank for clarify this, SA are too much expensive, I try check pinout to see if there where interchangeable in case I need dual image.
Screenshot from 2019-05-03 13:02:14.png
Thank you
