I have problems accessing dual ported ram in Modelsim.
My ram looks like this: component ram_megafunction is port ( address_a : IN STD_LOGIC_VECTOR (7 DOWNTO 0); address_b : IN STD_LOGIC_VECTOR (7 DOWNTO 0); clock : IN STD_LOGIC ; data_a : IN STD_LOGIC_VECTOR (31 DOWNTO 0); data_b : IN STD_LOGIC_VECTOR (31 DOWNTO 0); rden_a : IN STD_LOGIC := '0'; rden_b : IN STD_LOGIC := '0'; wren_a : IN STD_LOGIC := '0'; wren_b : IN STD_LOGIC := '0'; q_a : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); q_b : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); end component; when i write the following: data_in <= "10101010101010101010101010101010"; the resulting data_out is "X0X0X0X0X0X0X0X0X0X0X0X0X0X0X0X0"; What i am doing wrong? (Sorry for my bad english)Link Copied
It seems that you have multiple drivers on some signals. Forcing a signal to 0 and 1 at the same time will give an X.
You can check a few things: - do you have only one connection on data_a and data_b? - are you trying to write two different values from each port at the same address? - do you have only one connection to data_out?- Mark as New
Ok, thank you, i have found the problem.
data_out was driven twice.
