16655 Discussions
ERROR 209040:Can't access jtag chain
yao123
I need to load the .jic file through the command scripts----quartus_pgm,but the success rate of loading is low,only 10%,and it shows ERROR 209040:can't access jtag chain .But when i load through quartus prime 22.1 software,and it succeeds every time.How does this solve this problem?
quartus_pgm -c USB-Blaster[USB-0] -m jtag -o pvbi;D...
Fakhrul
Hi yao123,
There's a KDB regarding this issue, you can refer it here if
applicable:
https://www.intel.com/content/www/us/en/support/programmable/articles/000085212.html
Also, have you tried with another USB blaster? Here's also the similar case which you can refer:
DE0-Nano
Quartus Lite 19.1.0 Linux - Programming Failed - Error (209040): Can't access
JTAG chain
Qartus command prompt flashing is unsuccessful throwing "Can't access JTAG chain" error message
Fakhrul
Fakhrul
 As we do not receive any response from you on the previous question/reply/answer that we have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
