17000 Discussions
Early Place stage in Quartus flow
amildm
Valued Contributor I
As for the Early Place stage in the Quartus flow, when could it be useful?
1.png-----------------------------------------------------------------------------
 Thanks!
RichardTanSY_Intel
The Early Place feature has been removed from Quartus version 20.1 onward as it is of little value to most users so I don't really recommend to use it.
Early Place :
Begins assigning core design logic to device resources. After this stage, the Chip
Planner can display initial high-level placement of design elements. Use this
information to guide your floorplanning decisions.
Start Fitter (Place) :
Completes assignment of core design logic placement to device resources
Reference:
https://people.ece.cornell.edu/land/courses/ece5760/DE1_SOC/qts-qpp-handbook.pdf
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
RichardTanSY_Intel
Early Place :
Reference:
RichardTanSY_Intel
May I know does my reply helps to answer your question?
RichardTanSY_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
