16349 Discussions
Eclipse-nios crashes on startup (quartus 18.0)
SDe_J
Hello Intel Forums,
I am running Quartus 18.0 on a ubuntu 16.04 64 bit machine. When I try to run eclipse-nios, it crashes when I startup. I have also tried the eclipse-nios version included with quartus 18.1.
The version included with quartus 17.1 does work.
Attached is the beginning error log:
$> /intelFPGA/18.0/nios2eds/bin//eclipse-nios2 Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0 *** Error in `/oldhome/intelFPGA/18.0/quartus//linux64/jre64/bin/java': free(): invalid pointer: 0x00007f3949296200 *** ======= Backtrace: ========= /lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7f39af4a77e5] /lib/x86_64-linux-gnu/libc.so.6(+0x8037a)[0x7f39af4b037a] /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f39af4b453c] /oldhome/intelFPGA/18.0/quartus/linux64/libjtag_client.so(_ZNSs6assignERKSs+0x98)[0x7f390917ee58] /oldhome/intelFPGA/18.0/quartus/linux64/libboost_unit_test_framework.so.1.59.0(+0x4bc1b)[0x7f39082cfc1b] /oldhome/intelFPGA/18.0/quartus/linux64/libboost_unit_test_framework.so.1.59.0(+0x975b6)[0x7f390831b5b6] ======= Memory map: ======== 00400000-00401000 r-xp 00000000 08:10 21897299 /oldhome/intelFPGA/18.0/quartus/linux64/jre64/bin/java 00600000-00601000 rw-p 00000000 08:10 21897299 /oldhome/intelFPGA/18.0/quartus/linux64/jre64/bin/java 01aae000-01acf000 rw-p 00000000 00:00 0 [heap] ... ...
Ahmed_H_Intel1
Are you using now Eclipse 17.1 with Quartus 18.1?
