16346 Discussions
Embedded Timing Constraints
amildm
Valued Contributor I
Hi All,
What are the Embedded Timing Constraints? How to use them? Could they be defined by designers as well?
Thank you!
Nurina
Are you referring to embedded timing constraints in HDL code? I believe this has been answered in another thread you've posted: https://community.intel.com/t5/Intel-Quartus-Prime-Software/SDC-directives-in-HDL/m-p/1422441#M75617
Please let me know if you have additional questions.
Nurina
Nurina
We do not receive any response from you on the previous question/reply/answer provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
Nurina
