16824 Discussions
Error (0xc000007b) opening ModelSim
Dani82
I have an Asus ROG Zephyrus Core i 9 running on Windows 11 and am required to use Quartus Prime 18.1 version. When I try to open ModelSim, I get the error: "The application was unable to start correctly (0x000007b)."
Is there anything I can do to fix this issue?
SyafieqS
Have you tried to reinstall Quartus?
What is the step you took?
Dani82
I have reinstalled it a couple of times. I even tried the 20.1 version and tried to look for missing extensions or documents that might be the cause. (I thought this might be one: https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170) My computer is well capable enough to run it too, so I am clueless of what could be the issue. (Here is my system info)
sstrell
Running the older version with Windows 11 could be the problem.
Dani82
I know that is not the issue because I managed to run the same application and version on a Windows 11 Dell laptop core I 9 and it works. There is an extra file or necessary files that my computer does not have.
SyafieqS
That is weird, that is a good machine.
Have you tried to update Window etc?
Does the issue still persist?
Dani82
Ya, I still have the issue, I even downloaded the 21.1 version but it still does not open. I am surely missing a file on my computer but it does not tell me.
SyafieqS
Is is possible to use Questa instead?
Questa and Modelsim is same but Questa has better feature.
Modelsim will be EOL-ed and supported until 21.3 (if im not mistaken, might be wrong here), just saying.
SyafieqS
Let me know any update
SyafieqS
 As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
