17049 Discussions
Error 10349 in test bench
In my test bench I have the following
architecture test of test_limiter is ... signal high_limit_led :std_logic_vector(3 downto 0); signal low_limit_led :std_logic_vector(3 downto 0); ... component limiter is port(limit_low, limit_high, input :in std_logic_vector(3 downto 0); limit_low_led,limit_high_led,input_led : out std_logic_vector(3 downto 0); limit_high_display, limit_low_display, input_display : out std_logic_vector(6 downto 0); output : out std_logic_vector(6 downto 0); led_high, led_low : out std_logic); end component limiter; begin dut: limiter port map(..., input => test_input, low_limit_led => limit_low_led, high_limit_led => limit_high_led, ...);
however when I try to compile this I keep getting this error:
Error (10349): VHDL Association List error at test_limiter.vhd(30): formal "low_limit_led" does not exist
Please help. I've tried retyping all my other signals as well as just that signal and all of them are fine but that one... I have many of them before and after it but I can not figure it out.
--- Quote Start ---
--- Quote End ---
low_limit_led & limit_low_led? aren't you confusing yourself with such naming?
I believe you meant:
limit_low_led => low_limit_led; instead of low_limit_led => limit_low_led
--- Quote Start ---
--- Quote End ---
Oh opps thank you so much.
