16596 Discussions
Error (12061): Can't synthesize current design -- Top partition does not contain any logic
Amerakim
Hello, I am fairly new to Verilog HDL and I started with trying to print out a simple "hello world". But when i tried to synthesize my code, the error " Top partition does not contain ant logic" pops up. Anyone knows how to tackle this? i have set up the project and the top entity module name the same.
Any guidance would be much appreciated.
ak6dn
Valued Contributor III
Verilog that you feed into the synthesis tools needs to represent constructs that imply hardware (gates, registers, memory, etc).
You might start by reading this:
https://people.ece.cornell.edu/land/courses/ece5760/DE2/tut_quartus_intro_verilog.pdf
and this:
https://www.jameswhanlon.com/writing-synthesizable-verilog.html
If you had a module like this:
module top;
$write("Hello, world!");
endmodule
that is NOT a construct that can be synthesized into logic.
RichardTanSY_Intel
That kind of verilog code usually used for simulation purposes. Quartus is not a simulator tool, it Analyze & Synthesis code.
I believe the resources provided by ak6dn should be sufficient for you to learn.
Alternatively, you may checkout Nandland for beginner coding.
https://nandland.com/learn-verilog/
Have fun coding!
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
RichardTanSY_Intel
May I know do you need further help in regards to this case?
Richard Tan
RichardTanSY_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
