16606 Discussions
Error (12252): IP Helper Library GetAdaptersAddresses function failed
ArcticRain
With a project that compiled fine before, I now get the following error when compiling.
I have noticed this seemed to begin after a windows update was applied.
ArcticRain
Full error trace I am getting:
Exception in thread "main" java.lang.Error: IP Helper Library GetAdaptersAddresses function failed
    at java.net.NetworkInterface.isLoopback0(Native Method)
    at java.net.NetworkInterface.isLoopback(Unknown Source)
    at com.altera.sopcmodel.ensemble.Ensemble.makeUniqueIdentifier(Ensemble.java:712)
    at com.altera.sopcmodel.ensemble.Ensemble.init(Ensemble.java:472)
    at com.altera.sopcmodel.beanelement.BeanElementClass.newInstance(BeanElementClass.java:297)
    at com.altera.sopcmodel.ensemble.Ensemble.createQsys(Ensemble.java:681)
    at com.altera.sopcmodel.transforms.avalon.InitialInterconnectTransform.doExecute(InitialInterconnectTransform.java:91)
    at com.altera.sopcmodel.transforms.SopcTransformStep.execute(SopcTransformStep.java:66)
    at com.altera.sopcmodel.transforms.SopcTransformList.doExecute(SopcTransformList.java:112)
    at com.altera.sopcmodel.transforms.mm.MMTransform.doExecute(MMTransform.java:106)
    at com.altera.sopcmodel.transforms.avalon.AvalonTransform.doExecute(AvalonTransform.java:45)
    at com.altera.sopcmodel.ensemble.EnsembleUtils.doTransform(EnsembleUtils.java:1357)
    at com.altera.sopcmodel.components.tclmodule.LiveModuleGenerateComposedFileset.attemptComposedTransform(LiveModuleGenerateComposedFileset.java:124)
    at com.altera.sopcmodel.components.tclmodule.LiveModuleGenerateComposedFileset.generateComposedSet(LiveModuleGenerateComposedFileset.java:173)
    at com.altera.sopcmodel.components.tclmodule.LiveModuleGenerateComposedFileset.access$400(LiveModuleGenerateComposedFileset.java:40)
    at com.altera.sopcmodel.components.tclmodule.LiveModuleGenerateComposedFileset$AutoFileSet.generateAutoSet(LiveModuleGenerateComposedFileset.java:328)
    at com.altera.sopcmodel.components.tclmodule.LiveModuleGenerateComposedFileset$AutoFileSet.generate(LiveModuleGenerateComposedFileset.java:285)
    at com.altera.sopc.generator.FileSet2.generate(FileSet2.java:159)
    at com.altera.sopc.generator.Sellafield.generate(Sellafield.java:366)
    at com.altera.sopcmodel.sbtools.sbgenerate.SbGenerate.performGeneration(SbGenerate.java:521)
    at com.altera.sopcmodel.sbtools.sbgenerate.SbGenerate.act(SbGenerate.java:467)
    at com.altera.utilities.AltCmdLineToolBase.runTheTool(AltCmdLineToolBase.java:718)
    at com.altera.utilities.AltCmdLineToolBase.runTheTool(AltCmdLineToolBase.java:730)
    at com.altera.sopceditor.tools.generation.QsysGenerationTask.generateSynthesis(QsysGenerationTask.java:597)
    at com.altera.sopceditor.tools.generation.QsysGenerationTask.generate(QsysGenerationTask.java:374)
    at com.altera.sopceditor.tools.generation.QsysGenerationTask.run(QsysGenerationTask.java:127)
    at com.altera.qsys.generate.QsysGenerate.createGenerationTaskOuter(QsysGenerate.java:699)
    at com.altera.qsys.generate.QsysGenerate.runGenerationFlow(QsysGenerate.java:628)
    at com.altera.qsys.generate.QsysGenerate.act(QsysGenerate.java:389)
    at com.altera.qsys.generate.QsysGenerate.main(QsysGenerate.java:180)
Error generating Qsys
RichardTanSY_Intel
Is there a way that I can generate this error? probably sharing the design?
Not sure if this works, could you try to compile again by removing the qip file and just leaves the qsys file in the project?
ArcticRain
I am guessing this is a configuration error on my computer. I haven’t been able to reproduce it on other computers with the same project. Ryan Link Principal Engineer, Electrical +1 651 756 3308 ryan.link@abbott.com<mailto:ryan.link@abbott.com>
RichardTanSY_Intel
Have you try to reinstall Quartus software?
RichardTanSY_Intel
Since there are no feedback for this thread, I have already transition this thread to the community support. If you have a new question or need further help in this case, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
