Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
15382 Discussions
Error(13264): Can't resolve multiple constant drivers for net "s_wr_data[71][239]"
hi,
when i compile following code,quartus reported a error—— "Error(13264): Can't resolve multiple constant drivers for net "s_wr_data[71][239]" "
this problem puzzled me some time,how do i to sovle this problem?
Thanks in advance and best regards!
the code is as following:
parameter NUM_CE = 8; parameter NUM_BLOCK = 80; reg s_wr_data; reg s_wr_en; genvar i; generate for (i=0;i<NUM_CE;i=i+1) begin:WR_CTRL //write always @( *) begin case(I_conv_mod) 4'd0:begin if(loop_i==10'd0)begin s_wr_data = s_wr_ofmap_data_c1; s_wr_en = s_wr_ofmap_en_c1; end else if(loop_i==10'd1)begin s_wr_data = s_wr_ofmap_data_c1; s_wr_en = s_wr_ofmap_en_c1; end else if(loop_i==10'd2)begin s_wr_data = s_wr_ofmap_data_c1; s_wr_en = s_wr_ofmap_en_c1; end else if(loop_i==10'd3)begin s_wr_data = s_wr_ofmap_data_c1; s_wr_en = s_wr_ofmap_en_c1; end else if(loop_i==10'd4)begin s_wr_data = s_wr_ofmap_data_c1; s_wr_en = s_wr_ofmap_en_c1; end else if(loop_i==10'd5)begin s_wr_data = s_wr_ofmap_data_c1; s_wr_en = s_wr_ofmap_en_c1; end else begin s_wr_en = s_wr_en; end end 4'd1:begin if(loop4_3d==10'd0)begin s_wr_en = {s_wr_ofmap_en2,s_wr_ofmap_en1,s_wr_ofmap_en0}; //0~7 s_wr_data = s_wr_ofmap_data0; s_wr_data = s_wr_ofmap_data1; s_wr_data = s_wr_ofmap_data2; end else if(loop4_3d==10'd1)begin s_wr_en = {s_wr_ofmap_en2,s_wr_ofmap_en1,s_wr_ofmap_en0}; //0~7 s_wr_data = s_wr_ofmap_data0; s_wr_data = s_wr_ofmap_data1; s_wr_data = s_wr_ofmap_data2; end else if(loop4_3d==10'd2)begin s_wr_en = {s_wr_ofmap_en2,s_wr_ofmap_en1,s_wr_ofmap_en0}; //0~7 s_wr_data = s_wr_ofmap_data0; s_wr_data = s_wr_ofmap_data1; s_wr_data = s_wr_ofmap_data2; end else begin s_wr_en = s_wr_en; end end 4'd2,4'd3,4'd4,4'd5:begin if(loop8_3d==10'd0)begin s_wr_en = {s_wr_ofmap_en4,s_wr_ofmap_en3,s_wr_ofmap_en2,s_wr_ofmap_en1,s_wr_ofmap_en0}; //0~7 s_wr_data = s_wr_ofmap_data0; s_wr_data = s_wr_ofmap_data1; s_wr_data = s_wr_ofmap_data2; s_wr_data = s_wr_ofmap_data3; s_wr_data = s_wr_ofmap_data4; end else if(loop8_3d==10'd1)begin s_wr_en = {s_wr_ofmap_en4,s_wr_ofmap_en3,s_wr_ofmap_en2,s_wr_ofmap_en1,s_wr_ofmap_en0}; //0~7 s_wr_data = s_wr_ofmap_data0; s_wr_data = s_wr_ofmap_data1; s_wr_data = s_wr_ofmap_data2; s_wr_data = s_wr_ofmap_data3; s_wr_data = s_wr_ofmap_data4; end else begin s_wr_en = s_wr_en; end end default: begin s_wr_en = s_wr_en; end endcase end end endgenerate
I can only assume that some of the ranges for s_wr_data in the case statement overlap for different values of i.
each value of i in the generate loop produce parallel always blocks. And assigning the same bit in two always blocks will produce multiple drivers.
You havent posted the declarations of the following: i_conv_mod, NUM_BLOCK_k5_LOOP, NUM_BLOCK_k3_LOOP
