16215 Discussions
Error (14736): Error: Wizard "ALTFP_MULT" cannot be launched.
hi:
i ue quartus 15.0, use max10 10M08SAE144C8GES, i have following questions:
1. when i trying to add ALTFP_MULT ip, it shows:
but when i add ALTFP_DIV, it will be ok.
2.i also see ALTEAR_FP_FUMCTIOMS ip in the ip catalog,
what is the difference between ALTEAR_FP_FUMCTIOMS and ALTFP_MULT,ALTFP_DIV,ALTFP_ADD
3. where can i find the manual of these ips?
thanks!
nizar1976
Hi ,
   The topic is old but before creating another one ,  I will try to have the answer here.
I have exactly the same error  "Error (14736): Error: Wizard "ALTFP_MULT" cannot be launched."
with QUARTUS prime version 21.1.1 build 850 06/23/2022 SJ Standard Edition for a project on ARRIA V 5 AGXMA3D6F31C6.
When I try to open the wizard for other IPs for example ALTMEMMULT or LPM_MULT I have no error.
Is it a known issues of quartus 21.1.1 or I have another issue?
kabushawarib
Use "FP_FUNCTIONS Intel FPGA IP" instead.
