17010 Discussions
Error (15653): The Fitter cannot find a legal configuration for the following atoms
yy1
Arria 10
Error (15653): The Fitter cannot find a legal configuration for the following atoms. Update any outdated transceiver PHY IP cores, correct any illegal pin assignments, and then recompile your design
Error (15744): In atom 'ALTERA_RESERVED_FITTER_INSERTED_PMA_UC1'
Error (15744): The settings must match one or more of these conditions:
Error (15744): ( prot_mode != UNUSED ) OR ( vod_output_swing_ctrl == 0 )
Error (15744): But the following assignments violate the above conditions:
Error (15744): prot_mode = UNUSED
Error (15744): vod_output_swing_ctrl = 27
How can I resolve this bug?
Deshi_Intel
From the error log that you shared, I can see below 2 possible issues
  1. Is your NativePHY IP updated to match with your Quartus version ? If not then pls regenerate your NativePHY IP again
  2. Your PMA output VOD setting maybe causing some issue ?
  • Open your NativePHY IP to cross check again to ensure there is no warning or error message
    • Try out different output VOD setting
I can help you to review your design if you can share your design QAR file here.
dlim
Deshi_Intel
dlim
yy1
I find the code bug that the phy output port did not connect to any port.
Thanks for your reply.
Jamie
Deshi_Intel
Alright, I am glad that issue is resolved at your end !
