16558 Discussions
Error (209034): Can't find JTAG Server + JTAG server stopped
Nade786
I am using Win 10, Quartus 18.1 with an arrow-blaster (with latest driver installed).
I am trying to program a .jic file to my Altera Stratix V device.
However, the programming fails with the following error codes:
Error (209053): Unexpected error in JTAG server -- error code 44
Error (209012): Operation failed
I have tried running the programmer as administrator but it makes no difference to the end result.
Any help appreciated
Warm Regards
YuanLi_S_Intel
have you try to program a SOF file? does it work?
Also, can you check if you have the USB Blaster driver setup correctly?
Nade786
Hi Yuan,
Thank you for the reply.
1) I have tried to program a SOF file but it does give the same error as stated originally :
2) I am using an Arrow-blaster with the latest version (version 2.5) which can be found here ->
https://shop.trenz-electronic.de/Download/?path=Trenz_Electronic/Software/Drivers/Arrow_USB_Programmer/Arrow_USB_Programmer_2.5
The programmer is capable of locating the hardware under 'hardware setup' - please see attached image.
Thanks for the assistance,
Warm Regards
YuanLi_S_Intel
It seems like it might be the blaster issue / driver installation issue. Do you have Intel USB Blaster II to test with?
Nade786
Hi Yuan,
Sorry for the late reply... I have used multiple blasters in testing and have installed the latest drivers. It still did not seem to have solved the issue.
Fortunately,  I landed up us an Altera USB blaster and it did the job.
So I have parked this issue officially.
Thank you for the assistance.
