17267 Discussions
Error (213050): Convert Programming Files was NOT successful
asperkins
Hey there,
I am working on using LiteX to program the DE10Lite FPGA and have begun encountering an error when a Quartus command is evoked from the terminal. I will post the full logs below, but essentially I am trying to call the programmer from the command line and it is using an unsupported programming scheme. Ideally I would like to use JTAG, but I cannot find anywhere where I would specify this. Thanks!
Info: Running Quartus Prime Convert_programming_file
Info: Version 21.1.0 Build 842 10/21/2021 SJ Lite Edition
Info: Copyright (C) 2021 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Fri Feb 21 14:45:08 2025
Info: Command: quartus_cpf -c bcd_clock_display.sof bcd_clock_display.rbf
Device 10M50DAF484 does not support 1-bit Passive Serial scheme
Error (213050): Convert Programming Files was NOT successful -- refer to messages that appear above this message for more information
Error: Quartus Prime Convert_programming_file was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 324 megabytes
Error: Processing ended: Fri Feb 21 14:45:09 2025
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:00
Traceback (most recent call last):
File "/home/asperkins42@tntech.edu/Desktop/litex_labs/lab002/lab002.py", line 117, in <module>
platform.build(module, build_name="bcd_clock_display")
File "/home/asperkins42@tntech.edu/litex/litex/build/altera/platform.py", line 48, in build
return self.toolchain.build(self, *args, **kwargs)
File "/home/asperkins42@tntech.edu/litex/litex/build/altera/quartus.py", line 47, in build
return GenericToolchain.build(self, platform, fragment, **kwargs)
File "/home/asperkins42@tntech.edu/litex/litex/build/generic_toolchain.py", line 123, in build
self.run_script(script)
File "/home/asperkins42@tntech.edu/litex/litex/build/altera/quartus.py", line 248, in run_script
raise OSError("Error occured during Quartus's script execution.")
OSError: Error occured during Quartus's script execution.
FvM
you are trying to generate .rbf configuration file for MAX10 which isn't supported by CPF tool. MAX 10 has no configuration method that uses .rbf files. What are you trying to achieve?
NurAiman_M_Intel
May I know what are you trying to achieve? Please refer below configuration userguide for Max 10,
https://cdrdv2-public.intel.com/666495/ug-683865-666495.pdf
Aiman
NurAiman_M_Intel
Le me know if there is further support needed for this case.
Aiman
NurAiman_M_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
