I am trying SSS communication with Intel® Cyclone® 10 LP FPGA Evaluation Board.
The project is from
Then I got these two errors:
Error (292014): Can't find valid feature line for core SLL_CA_HBC_T001_Hyperbus_Memory_Controller_10min_trial_edition (AE7C_0014) in current license.
Error (10003): Can't open encrypted VHDL or Verilog HDL file "C:/Work/FPGA/C10_SSS/db/ip/q_sys/submodules/sll_ca_hbc_t001_top_enc.v" -- current license file does not contain a valid license for encrypted file
I can compile other projects successfully.
Also updated all license (University Program), tried 17.1, 19.1, 22.1std, nothing helped
There is similar post here (@AR_A_Intel)
It seems I need third-party license (if same reason), but no idea how/where to get it....
Very appreciate if anybody could help!!
Just realized that when compiling "golden_system_ref_design" downloading from Terasic, I get the same error.
Hello
Welcome to INTEL forum. Further check, can you provide detail below?
1) License.dat file
2) Screenshot of Quartus >> tools >> license setup
3) assembler report .asm.rpt file
• The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.
And for privacy, you can reply/attach your file in private message.
i have the same issue.
May i get the files to.
I like to play around with Cyclone 10 "golden_system_ref_design"
i like to try the "golden_system_ref_design" too.
Unfortunately, i was not able to get the license for the hyperbus IP.
There is a statement in some readme. I should contact Synaptic Labs
and ask for a license. I got a node locked license for a newer but
incompatible version. Useless for me as beginner.
For now, i can't try the "golden_system_ref_design" and the C10 FPGA board.
If somebody from intel is reading this request. Please provide the required
license for the "golden_system_ref_design".
Maik
Info (12021): Found 1 design units, including 1 entities, in source file db/ip/q_sys/submodules/q_sys_user_dipsw.v
Info (12023): Found entity 1: q_sys_user_dipsw
Error (292014): Can't find valid feature line for core SLL_CA_HBC_T001_Hyperbus_Memory_Controller_Opencore_edition (AE7C_000E) in current license.
Error (10003): Can't open encrypted VHDL or Verilog HDL file ".../fpga/c10/dl/cyclone10lp-10cl025yu256-eval-v17.0.0stdb595/cyclone10LP_10cl025yu256_eval_v17.0.0stdb595/examples/golden_system_ref_design/golden_system_ref_design/db/ip/q_sys/submodules/sll_ca_hbc_t001_top_enc.v" -- current license file does not contain a valid license for encrypted file
may i get the SLL_CA_HBC_T001_Hyperbus_Memory_Controller_10 license too.
Thank you very much.
Maik
We received and will respond you in the private message. TQ
Continue support in private message mail. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
I have the same problem with the reference design for the Intel® Cyclone® 10 LP Development Kit - I wonder if you could point me to the place where I can find the files.
I am using Quartus Prime standard 23.1 and getting these messages:
Error (10003): Can't open encrypted VHDL or Verilog HDL file "D:/X/eval_kits/collateral/examples/golden_system_ref_design/golden_system_ref_design/db/ip/q_sys/submodules/sll_ca_hbc_t001_top_enc.v" -- current license file does not contain a valid license for encrypted file
Any help is very much appreciated.
