Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Error: Can't find name for bus
Hi Guys,
I have a question concerning my Block-Editor-Project, which I have been working on. I have to connect a counter, which has a 20 bit Output to a lmp_compare-Symbol, which has a 20 bit Input.
Somehow Quartus complains while synthesis and gives me the error message:
If I click on the error message it shows the bus line I mentioned above. I always thought that, this bus line didn't need a name. I named the bus also, but that doesn't cure the problem.
Would be really great, if someone of you could give me a useful hint.
Thanks a lot!
Highlighted
Re: Error: Can't find name for bus
--- Quote Start ---
Hi Guys,
Thanks a lot!
--- Quote End ---
as far as I know you have to assign a name to the bus in your schematic.
Select the bus, right mouse click, choose properties and add a name like a[3..0].
Kind regards
GPK
Highlighted
Sorry for bothering you. I found the mistake. Guess, I was a bit tired yesterday, when i didn't see that I assigned two different names to the same busline.
Have a nice day!
