The error is related to a real value in the VCD file :
line 2440 : r2.1e-09 signal1
Older Versions did not show this error.
May I know how was the VCD generated in first place ?
In order to open a waveform using VCD, you need to convert VCD to WLF first.
Refer to KDB
Arslan
Thanks for sharing the VCD file.
Looking at your .vcd file
line 14 $var real 1 aaaal VIO $end It seems like bit width is set to 1.
$var type bitwidth id name
Try to increase the bit width to fix the issue.
Arslan
Hi MUsman,
thanks for your reply ...
Unfortunately the SystemC VCD writer is writing the file in this way. Older Version of Modelsim did not have this Problem.
Best regards
GPK
Per my understanding it is a problem from VCD writer side not Modelsim Intel side.
Arslan
Hi Arslan,
I found a solution for may Problem.
$var real 1 aaaal test $end
When I delete the width defintion of the real variable it works fine. Question is why ?
Best regards
GPK
