16920 Discussions
Error: TB_Gen: C012_FRAM.tcm is not exported for sim partner
Anonymous
Not applicable
Tool:Quartus Prime 22.1 std.0 Build915
IP : Tri-State Controller
When Tri-State Controller IP During Generate Testbench System, the following error occured . How should I fix it?
Info: send_message Error TB_Gen: C012_FRAM.tcm is not exported for sim partner
Error: Error: TB_Gen: C012_FRAM.tcm is not exported for sim partner
Info: Done
Error: There were errors creating the testbench system.
Info: Finished: Create testbench Platform Designer system
ShengN_Intel
Probably have to export C012_FRAM tcm port and connect externally with wire in rtl. Seems like there's something externally call sim partner.
Sheng
ShengN_Intel
Do you have any further concern or consideration on this thread?
Sheng
