Can You help me correct this problem in this code below:
module PWM( Ton,T,clk,Output_PWM); input clk; output Output_PWM; input [7:0] Ton; input [7:0] T; reg Output_PWM; integer a,i; initial begin a = 0; i = 0; end always@( posedge clk) begin if(i == 99999) begin i = 0; a= a +1; if(a <= T) begin if(a<= Ton) Output_PWM = 1; else Output_PWM = 0; end else a = 0; end end endmoduleLink Copied
Probably your project name is "bai3" but your top level module is "PWM". Go to Assigments->Settings and go to Top level entity and select PWM. Click OK and compile again.
add "bai3.v" to project and check if module name is bai3.v
add "bai3.v" to project and check if module name is "bai3" and set top module "bai3"
