Hello I'm trying to use the commandline flow with the following command:
quartus_sh --64bit --flow compile soc_system
however during the fitting something crashes. I'm using QuartusII/15.0
What could be causing this? Complete error below. Thanks!
Info (170196): Router estimated peak interconnect usage is 41% of the available device resources in the region that extends from location X11_Y0 to location X21_Y10
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_route_algorithm.c, Line: 4034
Internal Error
Stack Trace:
0xa8f1b: vpr_qi_jump_to_exit + 0x5f (fitter_vpr20kmain)
0x112d4a: vpr_exit_at_line + 0x83 (fitter_vpr20kmain)
0x76ae79: l_perform_post_iteration_operations + 0xe69 (fitter_vpr20kmain)
0x76b45c: l_run_single_routing_iteration + 0x38c (fitter_vpr20kmain)
0x76e59c: aa_route_alg_perform_timing_driven_route + 0xa2c (fitter_vpr20kmain)
0x771d65: aa_route_try_route + 0xb5 (fitter_vpr20kmain)
0x77fecb: l_do_single_routing_attempt + 0x33b (fitter_vpr20kmain)
0x78bf05: aa_flow_route + 0x35 (fitter_vpr20kmain)
0x78c573: aa_flow_fit + 0x43 (fitter_vpr20kmain)
0x6216b4: VPR_QI_FACADE::vpr_qi_main() + 0x24 (fitter_vpr20kmain)
0x608bd: fitapi_run_vpr + 0x4d (fitter_fitapi)
0x446c1: FSV_EXPERT_BASE::run_vpr() const + 0xc1 (fitter_fsv)
0x44f32: FSV_EXPERT_BASE::place_and_route() const + 0xc2 (fitter_fsv)
0x47134: FSV_EXPERT_BASE::invoke_fitter() const + 0xc84 (fitter_fsv)
0x42d92: fsv_execute + 0x2c2 (fitter_fsv)
0x29693: fmain_start(CMP_FACADE*) + 0x743 (fitter_fmain)
0x221e4: qfit_execute_fit(QCU_FRAMEWORK*, QFIT_FRAMEWORK*) + 0x174 (comp_qfit_legacy_flow)
0x1fcd2: QFIT_FRAMEWORK::execute() + 0x282 (comp_qfit_legacy_flow)
0x26b3f: qfit_legacy_flow_run_legacy_fitter_flow + 0x1af (comp_qfit_legacy_flow)
0x4d671: TclInvokeStringCommand + 0x81 (tcl8.6)
0x51ec7: TclNRRunCallbacks + 0x47 (tcl8.6)
0x536e7: TclEvalEx + 0x947 (tcl8.6)
0xfb366: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
0xfb47e: Tcl_EvalFile + 0x2e (tcl8.6)
0x1807a: qexe_evaluate_tcl_script(std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> > const&) + 0x382 (comp_qexe)
0x1c5c7: qexe_do_tcl(QEXE_FRAMEWORK*, std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> > const&, std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> > const&, std::list<std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > > const&, bool, bool) + 0x58c (comp_qexe)
0x1d60c: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > >*, bool) + 0x5c7 (comp_qexe)
0x51e86: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<std::basic_string<char, std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > >*, bool) + 0xbfc (comp_qcu)
0x1feb7: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x69d (comp_qexe)
0xc815: qfit2_main(int, char const**) + 0xc5 (quartus_fit)
0x49ef0: msg_main_thread(void*) + 0x10 (ccl_msg)
0x5d4c: thr_final_wrapper + 0xc (ccl_thr)
0x49fa5: msg_thread_wrapper(void* (*)(void*), void*) + 0x5b (ccl_msg)
0x20a2b: mem_thread_wrapper(void* (*)(void*), void*) + 0x9b (quartus_fit)
0x8def: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x6112: thr_thread_wrapper + 0x15 (ccl_thr)
0x4bee2: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xa3 (ccl_msg)
0x223d5: __libc_start_main + 0xf5 (c.so.6)
End-trace
- Tags:
- compilation
- synthesis
