17267 Discussions
Error creating session {R,T}xThread terminated W Nios II SBT debugger
Hi
I have so far had no luck in starting the debugger in Nios II SBT v10.0sp1
I have tried 2 boards (DE2-115) + (NEEK cyclone2c25), both with a quick build of the standard hello world project pr. turtorial guide.
every time I try to run debug as I get the following error message:
the console says:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x080001A8: verified
Listening on port 50644 for connection from GDB: 59s58s57s56s55s54s53s52s51s50s49s48s47s46s45s44s43s42s41s40s39s38s37s36s35s34s33s32s31s30s29s28s27s26s25s24s23s22s21s20s19s18s17s16s15s14s13s12s11s10s 9s 8s 7s 6s 5s 4s 3s 2s 1stimed out
Leaving target processor paused
content in the error log is the following:
!ENTRY com.altera.sbtgui.launch 1 0 2010-12-02 22:20:34.793
!MESSAGE Executing: [C:\Windows\system32\cmd.exe, /C, C:/altera/10.0sp1/quartus\bin\cygwin\bin\bash.exe, -c, nios2-download '--cable=USB-Blaster on localhost [USB-0]' --device=1 --instance=0 --sidp=0x80001a8 --id=0x3e1e5ebf --timestamp=1269914720 /cygdrive/c/altera/10.0sp1/projects/neek_standard/software/my_first_nios/my_first_nios.elf]
!ENTRY com.altera.sbtgui.launch 1 0 2010-12-02 22:20:38.711
!MESSAGE Executing: [C:\Windows\system32\cmd.exe, /C, C:/altera/10.0sp1/quartus\bin\cygwin\bin\bash.exe, -c, nios2-download '--cable=USB-Blaster on localhost [USB-0]' --device=1 --instance=0 --tcpport=auto --sidp=0x80001a8 --id=0x3e1e5ebf --timestamp=1269914720]
!ENTRY org.eclipse.cdt.debug.mi.core 4 150 2010-12-02 22:20:41.832
!MESSAGE Error creating session
!STACK 0
org.eclipse.cdt.debug.mi.core.MIException: {R,T}xThread terminated
at org.eclipse.cdt.debug.mi.core.MISession.postCommand(MISession.java:550)
at org.eclipse.cdt.debug.mi.core.MISession.postCommand(MISession.java:538)
at org.eclipse.cdt.debug.mi.core.MISession.initialize(MISession.java:329)
at org.eclipse.cdt.debug.mi.core.MISession.start(MISession.java:244)
at org.eclipse.cdt.debug.mi.core.AbstractGDBCDIDebugger.createSession(AbstractGDBCDIDebugger.java:81)
at com.altera.debug.cdi.gdb.plugin.Nios2GdbCdiDebugger.createSession(Nios2GdbCdiDebugger.java:61)
at com.altera.sbtgui.launch.hardware.Nios2HardwareLaunchDelegate.debugAction(Nios2HardwareLaunchDelegate.java:261)
at com.altera.sbtgui.launch.hardware.Nios2HardwareLaunchDelegate.launch(Nios2HardwareLaunchDelegate.java:124)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:866)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1069)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!SUBENTRY 1 org.eclipse.cdt.debug.mi.core 4 150 2010-12-02 22:20:41.832
!MESSAGE {R,T}xThread terminated
!STACK 0
I'm a bit newbee into the niosII eds tools and gdb so every input into getting the SBT debugger up and running will be welcome.
Was this problem ever resolved? I'm having the same problem.
I am using the Nios2 IDE 10.1SP1 on winxp system and had the same issue. It seems that after you install an additional plug-in on this Eclipse this error message occur.
I deinstalled the nios2eds and reinstalled it again after that all works fine. For me it was not sufficient to deinstall the plug-in(s) only.
I had the same problem NIOSII 10.1 SP1, it all started when I ran the Eclipse menu option Help>Check for updates. When I did this I received an update from one of the C++ developer patches from Eclipse and this seemed to cut the link to the Altera GDB debugger.
Again the solution is to uninstall NIOS2eds and reinstall.
You may not have to uninstall & reinstall Nios2EDS. Click "Help", choose "Search" and enter "revert" for instructions on how to revert Eclipse to a previous configuration. That's how I eventually corrected my problem, which started after allowing Eclipse to update itself.
Hm, same problem occoured for me today, after I've installed SVN plug-in. I need that plugin for libraries. Are there any chances to make it working without plug-in removal and/or reinstallation?
--- Quote Start ---
again the solution is to uninstall nios2eds and reinstall.
--- Quote End ---
That's what corrected the debugger issue for me as well. However, I still get errors in the error log that I didn't get before. :confused:
