17253 Discussions
Error during generating simulation code in Qsys
I am using Quartus lite 16.1 on Ubuntu 16.10. I have a design that I can synthesize and can run on DE1-SoC board, and I am trying to do some simulation with my design.
I am trying to generate testbench system by Generate -> Generate testbench system. I chose the simulation model to be verilog, and I wanted to create testbench qsys system as "Simple, BFMs for clocks and resets". However during generation, sys_pll is crashing. The log file seems to be not related to my design, and is related to the tool. Here is the log. Can I get some insights on how to fix this? The full log is in the attachment.
Error: sys_pll: Execution of script /tmp/alt7312_8544295832717336619.dir/0030_sys_pll_gen/proj.tcl failed
Error: sys_pll: Info: *******************************************************************
Error: sys_pll: Info: Running Quartus Prime Shell
Error: sys_pll: Info: Version 16.1.0 Build 196 10/24/2016 SJ Lite Edition
Error: sys_pll: Info: Copyright (C) 2016 Intel Corporation. All rights reserved.
Error: sys_pll: Info: Your use of Intel Corporation's design tools, logic functions
Error: sys_pll: Info: and other software and tools, and its AMPP partner logic
Error: sys_pll: Info: functions, and any output files from any of the foregoing
Error: sys_pll: Info: (including device programming or simulation files), and any
Error: sys_pll: Info: associated documentation or information are expressly subject
Error: sys_pll: Info: to the terms and conditions of the Intel Program License
Error: sys_pll: Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Error: sys_pll: Info: the Intel MegaCore Function License Agreement, or other
Error: sys_pll: Info: applicable license agreement, including, without limitation,
Error: sys_pll: Info: that your use is for the sole purpose of programming logic
Error: sys_pll: Info: devices manufactured by Intel and sold by Intel or its
Error: sys_pll: Info: authorized distributors. Please refer to the applicable
Error: sys_pll: Info: agreement for further details.
Error: sys_pll: Info: Processing started: Fri May 26 16:18:42 2017
Error: sys_pll: Info: Command: quartus_sh -t /tmp/alt7312_8544295832717336619.dir/0030_sys_pll_gen/proj.tcl
Error: sys_pll: Info (23030): Evaluation of Tcl script /tmp/alt7312_8544295832717336619.dir/0030_sys_pll_gen/proj.tcl was successful
Error: sys_pll: Info: Quartus Prime Shell was successful. 0 errors, 0 warnings
Error: sys_pll: Info: Peak virtual memory: 773 megabytes
Error: sys_pll: Info: Processing ended: Fri May 26 16:18:43 2017
Error: sys_pll: Info: Elapsed time: 00:00:01
Error: sys_pll: Info: Total CPU time (on all processors): 00:00:00
Error: sys_pll: Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed!
Error: sys_pll: Execution of script run_simgen_cmd.tcl failed
Error: sys_pll: Info: Processing started: Fri May 26 16:18:43 2017
Error: sys_pll: Info: Command: quartus_sh -t run_simgen_cmd.tcl
Error: sys_pll: Info: Running Quartus Prime Analysis & Synthesis
Error: sys_pll: Info: Processing started: Fri May 26 16:18:45 2017
Error: sys_pll: Info: Command: quartus_map Computer_System_System_PLL_sys_pll.qpf --simgen --ini=disable_check_quartus_compatibility_qsys_only=on --simgen_parameter=CBX_HDL_LANGUAGE=VERILOG
Error: sys_pll: Info: Total CPU time (on all processors): 00:00:36
Error: Generation stopped, 209 or more modules remaining
Error: qsys-generate failed with exit code 1: 155 Errors, 20 Warnings
Error: There were errors creating the testbench system.
Just to make sure: you've exported the PLL input reference clock from the system, correct? This is necessary for Qsys to automatically add the clock BFM when generating the testbench system.
I have the similar problem when generating the Altera PLL 16.1 wrapper... And I'm not using Qsys.
Is it a bug of version 16.1?
Just tried with 15.1 ... Simgen runs successfully. Cheers!
--- Quote Start ---
--- Quote End ---
