17268 Discussions
Error during the compilation
Ling_L_Intel
I download https://releases.rocketboards.org/release/2018.10/gsrd/a10_gsrd/a10_so> c_devkit_ghrd.tar.gz
 I met the following error from Quartus 18.1.
 Error(210039): File
 D:/intelFPGA_pro/18.1/projects/a10_soc_devkit_ghrd/output_files/ghrd_10a s066n2_time_limited.sof contains one or more time-limited
 megafunctions that support the Intel FPGA IP Evaluation Mode feature  that will not work after the hardware evaluation time expires. Refer to the Messages window for  evaluation time details.
> Error: Quartus Prime Assembler was unsuccessful. 1 error, 1 warning
>           Error: Peak virtual memory: 9839 megabytes
>           Error: Processing ended: Mon Dec 10 13:27:46 2018
>           Error: Elapsed time: 00:00:41
> It says this design contains " one or more time-limited Megafunctions  that support the Intel FPGA IP Evaluation Mode feature that will not  work after the hardware evaluation time expires"
> Could you give me some advice to solve the error?
Vicky1
Hi LLiu42,
This Error occurs because of the design contains one or more Megafunctions/IP which require separate license,but megafunctions/IP that support the Intel FPGA IP Evaluation Mode feature that allows to you do following things,
  •  Simulate the behavior of a licensed IP core in your system.
  • Verify the functionality, size, and speed of the IP core quickly and easily.
  • Generate time-limited device programming files for designs that include
  • Program a device with your IP core and verify your design in hardware.
You can use .sof file with Evaluation Mode while converting to any other programming file format you need to purchase separate license.
refer the below links for reference,
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd01212011_914.html?_ga=2.154004728.1748930846.1544504018-1214868127.1543822498
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an320.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
JET60200
Greeting,  I saw the same error when using qpro 18.1 to build :
a10_soc_devkit_ghrd.tar.gz
ERROR says same as reported by LiLiu42,
But when I checked "Synthesis IP Core Summary" Report, I don't find any IP cores which is marked as "un-licensed", the Summary as following:
Intel Corporation Signal Tap N/A N/A Licensed auto_fab_0|alt_sld_fab_0 1
Intel Corporation Signal Tap N/A N/A Licensed auto_fab_0|alt_sld_fab_0|alt_sld_fab_0 2
Intel Corporation Signal Tap N/A N/A Licensed auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins 3
Intel Corporation Signal Tap N/A N/A Licensed auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|atom_inst 4
Intel Corporation Signal Tap N/A N/A Licensed auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|atom_mod_inst 5
Intel Corporation Signal Tap N/A N/A Licensed auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|ocpfabric 6
Intel Corporation Signal Tap N/A N/A Licensed auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|sldfabric 7
Intel Corporation Signal Tap N/A N/A Licensed auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|splitter 8
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core 9
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_banks 10
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_banks|u_calculate_mode 11
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|pixel_channel_sync_conditioner 12
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|pixel_channel_sync_conditioner|internal_sync_signalling.gen_hdmi_syncs[0].pixel_lane_sync_generator 13
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|statemachine 14
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|stream_marker 15
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|scheduler 16
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|rd_ctrl 17
Intel Corporation Video and Image Processing Suite N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|sync_ctrl 18
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|clear_underflow_sticky_sync 19
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|enable_resync_sync 20
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|enable_sync 21
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|fp_sync 22
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|genlock_enable_sync 23
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|genlocked_sync 24
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|h_counter 25
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|input_fifo 26
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_banks|cmd_cvo_scheduler_encoder 27
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_banks|interlaced_field_sync 28
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_banks|resp_mode_banks_decoder 29
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_change_ack_trigger_sync 30
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_change_ack_trigger_sync|toggle_sync 31
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_change_trigger_sync 32
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|mode_change_trigger_sync|toggle_sync 33
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|pixel_lane_vertical_counter[0].v_counter 34
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|sof_cvi_locked_sync 35
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|sof_cvi_sync 36
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|stream_marker|cmd_decoder 37
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|cvo_core|underflow_sync 38
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|scheduler|cmd_control_slave_encoder 39
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|scheduler|cmd_mark_encoder 40
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|scheduler|cmd_mode_banks_encoder 41
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|scheduler|cmd_vib_encoder 42
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|scheduler|resp_control_slave_decoder 43
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|scheduler|resp_mode_banks_decoder 44
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|scheduler|resp_vib_decoder 45
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|sop_align 46
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_back 47
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_back|cmd_input 48
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_back|data_output 49
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_back|din_decoder 50
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_front 51
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_front|data_output 52
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_front|rsp_output 53
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_front|video_input 54
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in|vid_front|video_input|latency_converter 55
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd 56
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance 57
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|biram_reversed 58
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|control_signal_delay_line 59
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|load_msg_queue 60
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|mm_msg_queue 61
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|output_cid_delay_line 62
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|output_did_delay_line 63
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|output_msg_queue 64
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|read_ack_crosser 65
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|read_syn_crosser 66
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|READ_BLOCK.read_proc_instance|video_packet_encoder 67
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|pkt_trans_rd|cmd_input 68
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|rd_ctrl|dout_encoder 69
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|rd_ctrl|prioritze_bwdth.din_decoder 70
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|rd_ctrl|pt_cmd_encoder 71
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|rd_ctrl|sync_cmd_input 72
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|rd_ctrl|sync_resp_encoder 73
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|rd_ctrl|vob_cmd_encoder 74
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|sync_ctrl|READ_SIDE_INTERFACES.rd_cmd_encoder 75
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|sync_ctrl|READ_SIDE_INTERFACES.rd_resp_input 76
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|video_out 77
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|video_out|cmd_input 78
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|video_out|data_input 79
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|video_out|din_pipe_stage 80
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|video_out|video_output 81
Intel Corporation 6AF7_FFFF N/A N/A Licensed soc_inst|dp_0|frame_buf|alt_vip_cl_vfb_inst|video_out|video_output|latency_converter 82
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst 83
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top 84
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source 85
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source|bit_ctrl_status_cc 86
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source|dp_aux_bit_ctrl_source_u 87
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source|dp_aux_bit_ctrl_source_u|aux_ch_in_aux_cc 88
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source|rx_message_ack_av_cc 89
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source|rx_message_aux_cc 90
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source|timeout_reset_aux_cc 91
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source|tx_message_av_cc 92
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|aux_source|tx_message_count_aux_cc 93
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|dp_tx_scramble_i 94
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|enhanced_frame_dp_cc 95
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|hdcp_enable_dp_cc 96
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|hdcp_encryption_on_av_cc 97
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|hpd_16_cc 98
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|hpd_av_cc 99
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|hpd_from_event_clear_16_cc 100
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|hpd_monitor 101
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|hpd_to_event_clear_16_cc 102
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|mst_en_dp_cc 103
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|reset_0_cc 104
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|reset_1_cc 105
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|reset_2_cc 106
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|reset_3_cc 107
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|reset_4_cc 108
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|reset_dp_cc 109
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|ss_reset_0_cc 110
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|ss_reset_1_cc 111
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|ss_reset_2_cc 112
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|ss_reset_3_cc 113
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i 114
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|Hwidth_av_cc 115
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|MISC1_av_cc 116
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|Mvid_av_cc 117
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|Nvid_av_cc 118
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|VBIDreg_av_cc 119
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|Vheight_av_cc 120
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_misc0_enc_i 121
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i 122
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i|gearbox_fifo[0].gen_lane.bitec_dp_tx_gearbox_fifo_i 123
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i|gearbox_fifo[0].gen_lane.bitec_dp_tx_gearbox_fifo_i|bitec_dp_scfifo_i 124
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i|gearbox_fifo[1].gen_lanes.bitec_dp_tx_gearbox_fifo_i 125
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i|gearbox_fifo[1].gen_lanes.bitec_dp_tx_gearbox_fifo_i|bitec_dp_scfifo_i 126
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i|gearbox_fifo[2].gen_lanes.bitec_dp_tx_gearbox_fifo_i 127
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i|gearbox_fifo[2].gen_lanes.bitec_dp_tx_gearbox_fifo_i|bitec_dp_scfifo_i 128
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i|gearbox_fifo[3].gen_lanes.bitec_dp_tx_gearbox_fifo_i 129
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_gearbox_i|gearbox_fifo[3].gen_lanes.bitec_dp_tx_gearbox_fifo_i|bitec_dp_scfifo_i 130
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_packer_i 131
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_packer_i|buffer_fifo 132
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_pixel_steer_i 133
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_ss_mux_i 134
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_ss_pipeline_i 135
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_ss_pipeline_i|fifo 136
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_ss_sdp_sequencer_i 137
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_stream_mux_i 138
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_stream_mux_i|bitec_dp_tx_blank_start_gen_i 139
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_stream_mux_i|tx_bs_idle_gen_i 140
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bitec_dp_tx_stream_mux_i|tx_bs_vblank_gen_i 141
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|bpc_vid_cc 142
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|colour_cc 143
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|crc_vid_cc 144
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|dp_encode_msa_i 145
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|enc_vid_cc 146
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|misc176_cc 147
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|packetizer_sst.bitec_dp_tx_sst_pixel_packetizer_i 148
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|packetizer_sst.bitec_dp_tx_sst_pixel_packetizer_i|bitec_dp_tx_balance_fifo 149
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|packetizer_sst.bitec_dp_tx_sst_pixel_packetizer_i|bitec_dp_tx_balance_fifo|bitec_dp_scfifo_i 150
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|packetizer_sst.bitec_dp_tx_sst_pixel_packetizer_i|bitec_dp_tx_throttle_fifo 151
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|packetizer_sst.bitec_dp_tx_sst_pixel_packetizer_i|bitec_dp_tx_throttle_fifo|bitec_dp_scfifo_i 152
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|reset_videopipe_sync 153
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vblank_flag_cc 154
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vblank_flag_d_cc 155
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i 156
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|HSW_cc 157
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|Hstart_cc 158
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|Htotal_cc 159
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|Hwidth_cc 160
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|VSW_cc 161
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|Vheight_cc 162
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|Vstart_cc 163
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|Vtotal_cc 164
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|autotest_crc.crc_gen_b 165
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|autotest_crc.crc_gen_g 166
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|autotest_crc.crc_gen_r 167
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|bitec_cc_vidsyncs_i 168
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|bitec_cc_vidsyncs_i|bitec_dp_dcfifo_i 169
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|bitec_dp_tx_measure_vid_i 170
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|reset_videopipe_vid_sync 171
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|tpattern_idle_cc 172
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|tpattern_vid_cc 173
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|tx_gen_mvid_u 174
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|tx_gen_mvid_u|M_final_cc 175
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|tx_gen_mvid_u|M_reset_y_cc 176
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|tx_gen_mvid_u|reset_y_cc 177
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|tx_vsync_gen_i 178
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|vbid_flags_cc 179
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if.bitec_dp_tx_vid_if_i|vd2dp_fifo 180
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.HSP_av_cc 181
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.HSW_av_cc 182
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.Hstart_av_cc 183
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.Htotal_av_cc 184
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.MISC0_cc 185
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.VSP_av_cc 186
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.VSW_av_cc 187
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.Vstart_av_cc 188
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.bitec_dp_tx_stream_source_i|vid_if_roregs.Vtotal_av_cc 189
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|stream_source[0].bitec_dp_tx_stream_source_blk.tx0_reset_vid_u 190
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|tavg_ts_strm0_av_cc 191
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|tavg_ts_strm1_av_cc 192
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|tavg_ts_strm2_av_cc 193
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|tavg_ts_strm3_av_cc 194
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|timestamp_av_cc 195
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|tp_dp_cc 196
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|tx_80bit_patt_cc 197
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|tx_lane_count_dp_cc 198
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|vcp_id_strm0_av_cc 199
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|vcp_id_strm1_av_cc 200
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|vcp_id_strm2_av_cc 201
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|dp_encoder.tx_top|vcp_id_strm3_av_cc 202
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i 203
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_gxb_l[0].bitec_dp_tx_alt_gxb_cont_i 204
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_gxb_l[0].bitec_dp_tx_alt_gxb_cont_i|pll_locked_sync_cc 205
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_gxb_l[1].bitec_dp_tx_alt_gxb_cont_i 206
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_gxb_l[1].bitec_dp_tx_alt_gxb_cont_i|pll_locked_sync_cc 207
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_gxb_l[2].bitec_dp_tx_alt_gxb_cont_i 208
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_gxb_l[2].bitec_dp_tx_alt_gxb_cont_i|pll_locked_sync_cc 209
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_gxb_l[3].bitec_dp_tx_alt_gxb_cont_i 210
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_gxb_l[3].bitec_dp_tx_alt_gxb_cont_i|pll_locked_sync_cc 211
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_alt_pcs_i|tx_locked_sync 212
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i 213
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|bitec_dp_tx_skew_i 214
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[0].symb[0].gen_s0.bitec_dp_tx_8b10b_encode_i 215
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[0].symb[1].gen_s.bitec_dp_tx_8b10b_encode_i 216
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[0].symb[2].gen_s.bitec_dp_tx_8b10b_encode_i 217
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[0].symb[3].gen_s.bitec_dp_tx_8b10b_encode_i 218
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[1].symb[0].gen_s0.bitec_dp_tx_8b10b_encode_i 219
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[1].symb[1].gen_s.bitec_dp_tx_8b10b_encode_i 220
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[1].symb[2].gen_s.bitec_dp_tx_8b10b_encode_i 221
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[1].symb[3].gen_s.bitec_dp_tx_8b10b_encode_i 222
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[2].symb[0].gen_s0.bitec_dp_tx_8b10b_encode_i 223
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[2].symb[1].gen_s.bitec_dp_tx_8b10b_encode_i 224
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[2].symb[2].gen_s.bitec_dp_tx_8b10b_encode_i 225
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[2].symb[3].gen_s.bitec_dp_tx_8b10b_encode_i 226
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[3].symb[0].gen_s0.bitec_dp_tx_8b10b_encode_i 227
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[3].symb[1].gen_s.bitec_dp_tx_8b10b_encode_i 228
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[3].symb[2].gen_s.bitec_dp_tx_8b10b_encode_i 229
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|c8b_10b_lane_enc[3].symb[3].gen_s.bitec_dp_tx_8b10b_encode_i 230
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|prbs_gen.prbs7_gen 231
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.bitec_dp_tx_mac_i|zero_tx_cc 232
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.reset_sync 233
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.tx_busy_av_cc 234
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.tx_lane_count_cc 235
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.tx_link_rate_cc 236
N/A N/A Licensed soc_inst|dp_0|bitec_dp_0|altera_dp_inst|bitec_dp_inst|tx_mac.tx_preevolt_mac_cc 237
N/A QsysPrimePro 18.1 N/A N/A soc_inst qsys_top.qsys 238
N/A QsysPrimePro 18.1 N/A N/A soc_inst|dp_0 subsys_dp.qsys 239
Intel Corporation alt_sld_fab 18.1 N/A N/A auto_fab_0 qdb/.t/5f51c95d63b4.tmp/.temp/sld_fabrics/ipgen/alt_sld_fab_0/alt_sld_fab_0.ip 240
Intel Corporation alt_vip_cl_cvo 18.1 N/A N/A soc_inst|dp_0|cvo ip/subsys_dp/cvo.ip 241
Intel Corporation alt_vip_cl_vfb 18.1 N/A N/A soc_inst|dp_0|frame_buf ip/subsys_dp/frame_buf.ip 242
Intel Corporation alt_vip_video_input_bridge 18.1 N/A N/A soc_inst|dp_0|cvo|alt_vip_cl_cvo_inst|video_in ip/subsys_dp/cvo.ip 243
Intel Corporation altera_arria10_hps 18.1 N/A N/A soc_inst|a10_hps qsys_top.qsys 244
Intel Corporation altera_arria10_hps_io 18.1 N/A N/A soc_inst|a10_hps|hps_io qsys_top.qsys 245
Intel Corporation altera_avalon_dc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_0|async_fifo qsys_top.qsys 246
Intel Corporation altera_avalon_dc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_0|async_fifo_001 qsys_top.qsys 247
Intel Corporation altera_avalon_dc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_0|async_fifo_002 qsys_top.qsys 248
Intel Corporation altera_avalon_dc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_0|async_fifo_003 qsys_top.qsys 249
Intel Corporation altera_avalon_fifo 18.1 N/A N/A soc_inst|dp_0|aux_fifo ip/subsys_dp/aux_fifo.ip 250
Intel Corporation altera_avalon_jtag_uart 18.1 N/A N/A soc_inst|dp_0|jtag_uart ip/subsys_dp/jtag_uart.ip 251
Intel Corporation altera_avalon_mm_bridge 18.1 N/A N/A soc_inst|dp_0|pb_dp ip/subsys_dp/pb_dp.ip 252
Intel Corporation altera_avalon_mm_bridge 18.1 N/A N/A soc_inst|pb_lwh2f ip/qsys_top/pb_lwh2f.ip 253
Intel Corporation altera_avalon_onchip_memory2 18.1 N/A N/A soc_inst|dp_0|onchip_mem ip/subsys_dp/onchip_mem.ip 254
Intel Corporation altera_avalon_onchip_memory2 18.1 N/A N/A soc_inst|ocm_0 ip/qsys_top/ocm_0.ip 255
Intel Corporation altera_avalon_packets_to_master 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|transacto ip/qsys_top/hps_m.ip 256
Intel Corporation altera_avalon_packets_to_master 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|transacto ip/qsys_top/hps_m.ip 257
Intel Corporation altera_avalon_packets_to_master 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|transacto ip/qsys_top/hps_m.ip 258
Intel Corporation altera_avalon_pio 18.1 N/A N/A soc_inst|button_pio ip/qsys_top/button_pio.ip 259
Intel Corporation altera_avalon_pio 18.1 N/A N/A soc_inst|dipsw_pio ip/qsys_top/dipsw_pio.ip 260
Intel Corporation altera_avalon_pio 18.1 N/A N/A soc_inst|dp_0|pio_0 ip/subsys_dp/pio_0.ip 261
Intel Corporation altera_avalon_pio 18.1 N/A N/A soc_inst|dp_0|xdash ip/subsys_dp/xdash.ip 262
Intel Corporation altera_avalon_pio 18.1 N/A N/A soc_inst|led_pio ip/qsys_top/led_pio.ip 263
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|aux_fifo_in_csr_agent_rdata_fifo subsys_dp.qsys 264
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|aux_fifo_in_csr_agent_rsp_fifo subsys_dp.qsys 265
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|aux_fifo_out_agent_rdata_fifo subsys_dp.qsys 266
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|aux_fifo_out_agent_rsp_fifo subsys_dp.qsys 267
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|bitec_dp_0_tx_mgmt_agent_rsp_fifo subsys_dp.qsys 268
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cpu_debug_mem_slave_agent_rsp_fifo subsys_dp.qsys 269
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|jtag_uart_avalon_jtag_slave_agent_rsp_fifo subsys_dp.qsys 270
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|onchip_mem_s1_agent_rsp_fifo subsys_dp.qsys 271
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|pio_0_s1_agent_rsp_fifo subsys_dp.qsys 272
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|sys_timer_s1_agent_rsp_fifo subsys_dp.qsys 273
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|xdash_s1_agent_rsp_fifo subsys_dp.qsys 274
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|fifo ip/qsys_top/f2sdram2_m.ip 275
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|fifo ip/qsys_top/fpga_m.ip 276
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|fifo ip/qsys_top/hps_m.ip 277
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_0|a10_hps_f2sdram0_data_agent|async_fifo.read_rsp_fifo|my_altera_avalon_sc_fifo_wr qsys_top.qsys 278
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_0|a10_hps_f2sdram0_data_agent|async_fifo.write_rsp_fifo|my_altera_avalon_sc_fifo_wr qsys_top.qsys 279
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_1|ocm_0_s1_agent_rdata_fifo qsys_top.qsys 280
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_1|ocm_0_s1_agent_rsp_fifo qsys_top.qsys 281
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_2|pb_lwh2f_s0_agent_rdata_fifo qsys_top.qsys 282
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_2|pb_lwh2f_s0_agent_rsp_fifo qsys_top.qsys 283
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_3|button_pio_s1_agent_rsp_fifo qsys_top.qsys 284
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_3|dipsw_pio_s1_agent_rsp_fifo qsys_top.qsys 285
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_3|dp_0_alt_vip_cl_vfb_0_control_agent_rdata_fifo qsys_top.qsys 286
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_3|dp_0_alt_vip_cl_vfb_0_control_agent_rsp_fifo qsys_top.qsys 287
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_3|dp_0_pb_dp_s0_agent_rsp_fifo qsys_top.qsys 288
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_3|ilc_avalon_slave_agent_rsp_fifo qsys_top.qsys 289
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_3|led_pio_s1_agent_rsp_fifo qsys_top.qsys 290
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_3|sys_id_control_slave_agent_rsp_fifo qsys_top.qsys 291
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_4|a10_hps_f2h_axi_slave_agent|async_fifo.read_rsp_fifo|my_altera_avalon_sc_fifo_wr qsys_top.qsys 292
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_4|a10_hps_f2h_axi_slave_agent|async_fifo.write_rsp_fifo|my_altera_avalon_sc_fifo_wr qsys_top.qsys 293
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_5|a10_hps_f2sdram2_data_agent|async_fifo.read_rsp_fifo|my_altera_avalon_sc_fifo_wr qsys_top.qsys 294
Intel Corporation altera_avalon_sc_fifo 18.1 N/A N/A soc_inst|mm_interconnect_5|a10_hps_f2sdram2_data_agent|async_fifo.write_rsp_fifo|my_altera_avalon_sc_fifo_wr qsys_top.qsys 295
Intel Corporation altera_avalon_st_adapter 18.1 N/A N/A soc_inst|dp_0|avalon_st_adapter subsys_dp.qsys 296
Intel Corporation altera_avalon_st_bytes_to_packets 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|b2p ip/qsys_top/hps_m.ip 297
Intel Corporation altera_avalon_st_bytes_to_packets 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|b2p ip/qsys_top/hps_m.ip 298
Intel Corporation altera_avalon_st_bytes_to_packets 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|b2p ip/qsys_top/hps_m.ip 299
Intel Corporation altera_avalon_st_handshake_clock_crosser 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|crosser subsys_dp.qsys 300
Intel Corporation altera_avalon_st_handshake_clock_crosser 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|crosser_001 subsys_dp.qsys 301
Intel Corporation altera_avalon_st_handshake_clock_crosser 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|crosser_002 subsys_dp.qsys 302
Intel Corporation altera_avalon_st_handshake_clock_crosser 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|crosser_003 subsys_dp.qsys 303
Intel Corporation altera_avalon_st_handshake_clock_crosser 18.1 N/A N/A soc_inst|mm_interconnect_3|crosser qsys_top.qsys 304
Intel Corporation altera_avalon_st_handshake_clock_crosser 18.1 N/A N/A soc_inst|mm_interconnect_3|crosser_001 qsys_top.qsys 305
Intel Corporation altera_avalon_st_packets_to_bytes 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|p2b ip/qsys_top/hps_m.ip 306
Intel Corporation altera_avalon_st_packets_to_bytes 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|p2b ip/qsys_top/hps_m.ip 307
Intel Corporation altera_avalon_st_packets_to_bytes 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|p2b ip/qsys_top/hps_m.ip 308
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|agent_pipeline qsys_top.qsys 309
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|agent_pipeline_001 qsys_top.qsys 310
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|agent_pipeline_002 qsys_top.qsys 311
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|agent_pipeline_003 qsys_top.qsys 312
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|limiter_pipeline qsys_top.qsys 313
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|limiter_pipeline_001 qsys_top.qsys 314
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|mux_pipeline qsys_top.qsys 315
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|mux_pipeline_001 qsys_top.qsys 316
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|mux_pipeline_002 qsys_top.qsys 317
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_0|mux_pipeline_003 qsys_top.qsys 318
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_1|agent_pipeline qsys_top.qsys 319
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_1|agent_pipeline_001 qsys_top.qsys 320
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_1|mux_pipeline qsys_top.qsys 321
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_1|mux_pipeline_001 qsys_top.qsys 322
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_1|mux_pipeline_002 qsys_top.qsys 323
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_1|mux_pipeline_003 qsys_top.qsys 324
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_2|agent_pipeline qsys_top.qsys 325
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_2|agent_pipeline_001 qsys_top.qsys 326
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_2|mux_pipeline qsys_top.qsys 327
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_2|mux_pipeline_001 qsys_top.qsys 328
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_2|mux_pipeline_002 qsys_top.qsys 329
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_2|mux_pipeline_003 qsys_top.qsys 330
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_2|mux_pipeline_004 qsys_top.qsys 331
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_2|mux_pipeline_005 qsys_top.qsys 332
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline qsys_top.qsys 333
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_001 qsys_top.qsys 334
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_002 qsys_top.qsys 335
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_003 qsys_top.qsys 336
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_004 qsys_top.qsys 337
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_005 qsys_top.qsys 338
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_006 qsys_top.qsys 339
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_007 qsys_top.qsys 340
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_008 qsys_top.qsys 341
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_009 qsys_top.qsys 342
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_010 qsys_top.qsys 343
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_011 qsys_top.qsys 344
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_012 qsys_top.qsys 345
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|agent_pipeline_013 qsys_top.qsys 346
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|limiter_pipeline qsys_top.qsys 347
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|limiter_pipeline_001 qsys_top.qsys 348
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline qsys_top.qsys 349
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_001 qsys_top.qsys 350
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_002 qsys_top.qsys 351
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_003 qsys_top.qsys 352
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_004 qsys_top.qsys 353
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_005 qsys_top.qsys 354
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_006 qsys_top.qsys 355
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_007 qsys_top.qsys 356
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_008 qsys_top.qsys 357
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_009 qsys_top.qsys 358
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_010 qsys_top.qsys 359
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_011 qsys_top.qsys 360
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_012 qsys_top.qsys 361
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_3|mux_pipeline_013 qsys_top.qsys 362
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|agent_pipeline qsys_top.qsys 363
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|agent_pipeline_001 qsys_top.qsys 364
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|agent_pipeline_002 qsys_top.qsys 365
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|agent_pipeline_003 qsys_top.qsys 366
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|limiter_pipeline qsys_top.qsys 367
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|limiter_pipeline_001 qsys_top.qsys 368
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|mux_pipeline qsys_top.qsys 369
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|mux_pipeline_001 qsys_top.qsys 370
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|mux_pipeline_002 qsys_top.qsys 371
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_4|mux_pipeline_003 qsys_top.qsys 372
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|agent_pipeline qsys_top.qsys 373
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|agent_pipeline_001 qsys_top.qsys 374
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|agent_pipeline_002 qsys_top.qsys 375
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|agent_pipeline_003 qsys_top.qsys 376
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|limiter_pipeline qsys_top.qsys 377
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|limiter_pipeline_001 qsys_top.qsys 378
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|mux_pipeline qsys_top.qsys 379
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|mux_pipeline_001 qsys_top.qsys 380
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|mux_pipeline_002 qsys_top.qsys 381
Intel Corporation altera_avalon_st_pipeline_stage 18.1 N/A N/A soc_inst|mm_interconnect_5|mux_pipeline_003 qsys_top.qsys 382
Intel Corporation altera_avalon_sysid_qsys 18.1 N/A N/A soc_inst|sys_id ip/qsys_top/sys_id.ip 383
Intel Corporation altera_avalon_timer 18.1 N/A N/A soc_inst|dp_0|sys_timer ip/subsys_dp/sys_timer.ip 384
Intel Corporation altera_a10_xcvr_reset_sequencer 18.1 N/A N/A auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|a10xcvrfabric qdb/.t/5f51c95d63b4.tmp/.temp/sld_fabrics/ipgen/alt_sld_fab_0/alt_sld_fab_0.ip 385
Intel Corporation altera_dp 18.1 N/A N/A soc_inst|dp_0|bitec_dp_0 ip/subsys_dp/bitec_dp_0.ip 386
Intel Corporation altera_emif_arch_nf 18.1 N/A N/A soc_inst|emif_hps|altera_emif_a10_hps_inst|arch ip/qsys_top/emif_hps.ip 387
Intel Corporation altera_emif_a10_hps 18.1 N/A N/A soc_inst|emif_hps ip/qsys_top/emif_hps.ip 388
Intel Corporation altera_gpio 18.1 N/A N/A buslvds_i|b2v_inst5 diffin.qsys 389
Intel Corporation altera_gpio_core20 18.1 N/A N/A buslvds_i|b2v_inst5|diffin|core diffin.qsys 390
Intel Corporation altera_in_system_sources_probes 18.1 N/A N/A soc_inst|issp_0 ip/qsys_top/issp_0.ip 391
Intel Corporation altera_in_system_sources_probes 18.1 N/A N/A soc_inst|issp_dp ip/qsys_top/issp_dp.ip 392
Intel Corporation altera_iopll 18.1 N/A N/A soc_inst|dp_0|video_pll ip/subsys_dp/video_pll.ip 393
Intel Corporation altera_irq_clock_crosser 18.1 N/A N/A soc_inst|dp_0|irq_synchronizer subsys_dp.qsys 394
Intel Corporation altera_irq_mapper 18.1 N/A N/A soc_inst|dp_0|irq_mapper subsys_dp.qsys 395
Intel Corporation altera_irq_mapper 18.1 N/A N/A soc_inst|irq_mapper qsys_top.qsys 396
Intel Corporation altera_irq_mapper 18.1 N/A N/A soc_inst|irq_mapper_001 qsys_top.qsys 397
Intel Corporation altera_irq_mapper 18.1 N/A N/A soc_inst|irq_mapper_002 qsys_top.qsys 398
Intel Corporation altera_jtag_avalon_master 18.1 N/A N/A soc_inst|f2sdram2_m ip/qsys_top/f2sdram2_m.ip 399
Intel Corporation altera_jtag_avalon_master 18.1 N/A N/A soc_inst|fpga_m ip/qsys_top/fpga_m.ip 400
Intel Corporation altera_jtag_avalon_master 18.1 N/A N/A soc_inst|hps_m ip/qsys_top/hps_m.ip 401
Intel Corporation altera_jtag_dc_streaming 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|jtag_phy_embedded_in_jtag_master ip/qsys_top/hps_m.ip 402
Intel Corporation altera_jtag_dc_streaming 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|jtag_phy_embedded_in_jtag_master ip/qsys_top/hps_m.ip 403
Intel Corporation altera_jtag_dc_streaming 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|jtag_phy_embedded_in_jtag_master ip/qsys_top/hps_m.ip 404
Intel Corporation altera_merlin_axi_master_ni 18.1 N/A N/A soc_inst|mm_interconnect_1|a10_hps_h2f_axi_master_agent qsys_top.qsys 405
Intel Corporation altera_merlin_axi_master_ni 18.1 N/A N/A soc_inst|mm_interconnect_2|a10_hps_h2f_lw_axi_master_agent qsys_top.qsys 406
Intel Corporation altera_merlin_axi_slave_ni 18.1 N/A N/A soc_inst|mm_interconnect_0|a10_hps_f2sdram0_data_agent qsys_top.qsys 407
Intel Corporation altera_merlin_axi_slave_ni 18.1 N/A N/A soc_inst|mm_interconnect_4|a10_hps_f2h_axi_slave_agent qsys_top.qsys 408
Intel Corporation altera_merlin_axi_slave_ni 18.1 N/A N/A soc_inst|mm_interconnect_5|a10_hps_f2sdram2_data_agent qsys_top.qsys 409
Intel Corporation altera_merlin_burst_adapter 18.1 N/A N/A soc_inst|mm_interconnect_0|a10_hps_f2sdram0_data_rd_burst_adapter qsys_top.qsys 410
Intel Corporation altera_merlin_burst_adapter 18.1 N/A N/A soc_inst|mm_interconnect_0|a10_hps_f2sdram0_data_wr_burst_adapter qsys_top.qsys 411
Intel Corporation altera_merlin_burst_adapter 18.1 N/A N/A soc_inst|mm_interconnect_1|ocm_0_s1_burst_adapter qsys_top.qsys 412
Intel Corporation altera_merlin_burst_adapter 18.1 N/A N/A soc_inst|mm_interconnect_2|pb_lwh2f_s0_burst_adapter qsys_top.qsys 413
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_demux subsys_dp.qsys 414
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_demux_001 subsys_dp.qsys 415
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_demux_002 subsys_dp.qsys 416
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux subsys_dp.qsys 417
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux_001 subsys_dp.qsys 418
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux_002 subsys_dp.qsys 419
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux_003 subsys_dp.qsys 420
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux_004 subsys_dp.qsys 421
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux_005 subsys_dp.qsys 422
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux_006 subsys_dp.qsys 423
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux_007 subsys_dp.qsys 424
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_demux_008 subsys_dp.qsys 425
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_0|cmd_demux qsys_top.qsys 426
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_0|rsp_demux qsys_top.qsys 427
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_0|rsp_demux_001 qsys_top.qsys 428
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_1|cmd_demux qsys_top.qsys 429
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_1|cmd_demux_001 qsys_top.qsys 430
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_1|rsp_demux qsys_top.qsys 431
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_2|cmd_demux qsys_top.qsys 432
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_2|cmd_demux_001 qsys_top.qsys 433
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_2|cmd_demux_002 qsys_top.qsys 434
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_2|rsp_demux qsys_top.qsys 435
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|cmd_demux qsys_top.qsys 436
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|rsp_demux qsys_top.qsys 437
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|rsp_demux_001 qsys_top.qsys 438
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|rsp_demux_002 qsys_top.qsys 439
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|rsp_demux_003 qsys_top.qsys 440
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|rsp_demux_004 qsys_top.qsys 441
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|rsp_demux_005 qsys_top.qsys 442
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|rsp_demux_006 qsys_top.qsys 443
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_4|cmd_demux qsys_top.qsys 444
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_4|rsp_demux qsys_top.qsys 445
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_4|rsp_demux_001 qsys_top.qsys 446
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_5|cmd_demux qsys_top.qsys 447
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_5|rsp_demux qsys_top.qsys 448
Intel Corporation altera_merlin_demultiplexer 18.1 N/A N/A soc_inst|mm_interconnect_5|rsp_demux_001 qsys_top.qsys 449
Intel Corporation altera_merlin_master_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cpu_data_master_agent subsys_dp.qsys 450
Intel Corporation altera_merlin_master_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cpu_instruction_master_agent subsys_dp.qsys 451
Intel Corporation altera_merlin_master_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|pb_dp_m0_agent subsys_dp.qsys 452
Intel Corporation altera_merlin_master_agent 18.1 N/A N/A soc_inst|mm_interconnect_0|dp_0_alt_vip_cl_vfb_0_mem_master_rd_agent qsys_top.qsys 453
Intel Corporation altera_merlin_master_agent 18.1 N/A N/A soc_inst|mm_interconnect_2|fpga_m_master_agent qsys_top.qsys 454
Intel Corporation altera_merlin_master_agent 18.1 N/A N/A soc_inst|mm_interconnect_3|pb_lwh2f_m0_agent qsys_top.qsys 455
Intel Corporation altera_merlin_master_agent 18.1 N/A N/A soc_inst|mm_interconnect_4|hps_m_master_agent qsys_top.qsys 456
Intel Corporation altera_merlin_master_agent 18.1 N/A N/A soc_inst|mm_interconnect_5|f2sdram2_m_master_agent qsys_top.qsys 457
Intel Corporation altera_merlin_master_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cpu_data_master_translator subsys_dp.qsys 458
Intel Corporation altera_merlin_master_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cpu_instruction_master_translator subsys_dp.qsys 459
Intel Corporation altera_merlin_master_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|pb_dp_m0_translator subsys_dp.qsys 460
Intel Corporation altera_merlin_master_translator 18.1 N/A N/A soc_inst|mm_interconnect_0|dp_0_alt_vip_cl_vfb_0_mem_master_rd_translator qsys_top.qsys 461
Intel Corporation altera_merlin_master_translator 18.1 N/A N/A soc_inst|mm_interconnect_2|fpga_m_master_translator qsys_top.qsys 462
Intel Corporation altera_merlin_master_translator 18.1 N/A N/A soc_inst|mm_interconnect_3|pb_lwh2f_m0_translator qsys_top.qsys 463
Intel Corporation altera_merlin_master_translator 18.1 N/A N/A soc_inst|mm_interconnect_4|hps_m_master_translator qsys_top.qsys 464
Intel Corporation altera_merlin_master_translator 18.1 N/A N/A soc_inst|mm_interconnect_5|f2sdram2_m_master_translator qsys_top.qsys 465
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux subsys_dp.qsys 466
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux_001 subsys_dp.qsys 467
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux_002 subsys_dp.qsys 468
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux_003 subsys_dp.qsys 469
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux_004 subsys_dp.qsys 470
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux_005 subsys_dp.qsys 471
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux_006 subsys_dp.qsys 472
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux_007 subsys_dp.qsys 473
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cmd_mux_008 subsys_dp.qsys 474
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_mux subsys_dp.qsys 475
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_mux_001 subsys_dp.qsys 476
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|rsp_mux_002 subsys_dp.qsys 477
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_0|cmd_mux qsys_top.qsys 478
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_0|cmd_mux_001 qsys_top.qsys 479
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_0|rsp_mux qsys_top.qsys 480
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_1|cmd_mux qsys_top.qsys 481
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_1|rsp_mux qsys_top.qsys 482
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_1|rsp_mux_001 qsys_top.qsys 483
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_2|cmd_mux qsys_top.qsys 484
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_2|rsp_mux qsys_top.qsys 485
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_2|rsp_mux_001 qsys_top.qsys 486
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_2|rsp_mux_002 qsys_top.qsys 487
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|cmd_mux qsys_top.qsys 488
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|cmd_mux_001 qsys_top.qsys 489
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|cmd_mux_002 qsys_top.qsys 490
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|cmd_mux_003 qsys_top.qsys 491
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|cmd_mux_004 qsys_top.qsys 492
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|cmd_mux_005 qsys_top.qsys 493
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|cmd_mux_006 qsys_top.qsys 494
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_3|rsp_mux qsys_top.qsys 495
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_4|cmd_mux qsys_top.qsys 496
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_4|cmd_mux_001 qsys_top.qsys 497
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_4|rsp_mux qsys_top.qsys 498
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_5|cmd_mux qsys_top.qsys 499
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_5|cmd_mux_001 qsys_top.qsys 500
Intel Corporation altera_merlin_multiplexer 18.1 N/A N/A soc_inst|mm_interconnect_5|rsp_mux qsys_top.qsys 501
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router subsys_dp.qsys 502
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_001 subsys_dp.qsys 503
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_002 subsys_dp.qsys 504
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_003 subsys_dp.qsys 505
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_004 subsys_dp.qsys 506
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_005 subsys_dp.qsys 507
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_006 subsys_dp.qsys 508
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_007 subsys_dp.qsys 509
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_008 subsys_dp.qsys 510
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_009 subsys_dp.qsys 511
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_010 subsys_dp.qsys 512
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|router_011 subsys_dp.qsys 513
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_0|router qsys_top.qsys 514
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_0|router_001 qsys_top.qsys 515
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_0|router_002 qsys_top.qsys 516
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_1|router qsys_top.qsys 517
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_1|router_001 qsys_top.qsys 518
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_1|router_002 qsys_top.qsys 519
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_2|router qsys_top.qsys 520
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_2|router_001 qsys_top.qsys 521
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_2|router_002 qsys_top.qsys 522
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_2|router_003 qsys_top.qsys 523
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_3|router qsys_top.qsys 524
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_3|router_001 qsys_top.qsys 525
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_3|router_002 qsys_top.qsys 526
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_3|router_003 qsys_top.qsys 527
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_3|router_004 qsys_top.qsys 528
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_3|router_005 qsys_top.qsys 529
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_3|router_006 qsys_top.qsys 530
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_3|router_007 qsys_top.qsys 531
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_4|router qsys_top.qsys 532
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_4|router_001 qsys_top.qsys 533
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_4|router_002 qsys_top.qsys 534
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_5|router qsys_top.qsys 535
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_5|router_001 qsys_top.qsys 536
Intel Corporation altera_merlin_router 18.1 N/A N/A soc_inst|mm_interconnect_5|router_002 qsys_top.qsys 537
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|aux_fifo_in_csr_agent subsys_dp.qsys 538
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|aux_fifo_out_agent subsys_dp.qsys 539
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|bitec_dp_0_tx_mgmt_agent subsys_dp.qsys 540
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cpu_debug_mem_slave_agent subsys_dp.qsys 541
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|jtag_uart_avalon_jtag_slave_agent subsys_dp.qsys 542
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|onchip_mem_s1_agent subsys_dp.qsys 543
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|pio_0_s1_agent subsys_dp.qsys 544
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|sys_timer_s1_agent subsys_dp.qsys 545
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|xdash_s1_agent subsys_dp.qsys 546
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_1|ocm_0_s1_agent qsys_top.qsys 547
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_2|pb_lwh2f_s0_agent qsys_top.qsys 548
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_3|button_pio_s1_agent qsys_top.qsys 549
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_3|dipsw_pio_s1_agent qsys_top.qsys 550
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_3|dp_0_alt_vip_cl_vfb_0_control_agent qsys_top.qsys 551
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_3|dp_0_pb_dp_s0_agent qsys_top.qsys 552
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_3|ilc_avalon_slave_agent qsys_top.qsys 553
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_3|led_pio_s1_agent qsys_top.qsys 554
Intel Corporation altera_merlin_slave_agent 18.1 N/A N/A soc_inst|mm_interconnect_3|sys_id_control_slave_agent qsys_top.qsys 555
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|aux_fifo_in_csr_translator subsys_dp.qsys 556
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|aux_fifo_out_translator subsys_dp.qsys 557
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|bitec_dp_0_tx_mgmt_translator subsys_dp.qsys 558
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|cpu_debug_mem_slave_translator subsys_dp.qsys 559
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|jtag_uart_avalon_jtag_slave_translator subsys_dp.qsys 560
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|onchip_mem_s1_translator subsys_dp.qsys 561
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|pio_0_s1_translator subsys_dp.qsys 562
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|sys_timer_s1_translator subsys_dp.qsys 563
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0|xdash_s1_translator subsys_dp.qsys 564
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_1|ocm_0_s1_translator qsys_top.qsys 565
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_2|pb_lwh2f_s0_translator qsys_top.qsys 566
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_3|button_pio_s1_translator qsys_top.qsys 567
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_3|dipsw_pio_s1_translator qsys_top.qsys 568
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_3|dp_0_alt_vip_cl_vfb_0_control_translator qsys_top.qsys 569
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_3|dp_0_pb_dp_s0_translator qsys_top.qsys 570
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_3|ilc_avalon_slave_translator qsys_top.qsys 571
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_3|led_pio_s1_translator qsys_top.qsys 572
Intel Corporation altera_merlin_slave_translator 18.1 N/A N/A soc_inst|mm_interconnect_3|sys_id_control_slave_translator qsys_top.qsys 573
Intel Corporation altera_merlin_traffic_limiter 18.1 N/A N/A soc_inst|mm_interconnect_0|dp_0_alt_vip_cl_vfb_0_mem_master_rd_limiter qsys_top.qsys 574
Intel Corporation altera_merlin_traffic_limiter 18.1 N/A N/A soc_inst|mm_interconnect_3|pb_lwh2f_m0_limiter qsys_top.qsys 575
Intel Corporation altera_merlin_traffic_limiter 18.1 N/A N/A soc_inst|mm_interconnect_4|hps_m_master_limiter qsys_top.qsys 576
Intel Corporation altera_merlin_traffic_limiter 18.1 N/A N/A soc_inst|mm_interconnect_5|f2sdram2_m_master_limiter qsys_top.qsys 577
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_1|ocm_0_s1_cmd_width_adapter qsys_top.qsys 578
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_1|ocm_0_s1_rsp_width_adapter qsys_top.qsys 579
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_4|a10_hps_f2h_axi_slave_rd_cmd_width_adapter qsys_top.qsys 580
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_4|a10_hps_f2h_axi_slave_rd_rsp_width_adapter qsys_top.qsys 581
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_4|a10_hps_f2h_axi_slave_wr_cmd_width_adapter qsys_top.qsys 582
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_4|a10_hps_f2h_axi_slave_wr_rsp_width_adapter qsys_top.qsys 583
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_5|a10_hps_f2sdram2_data_rd_cmd_width_adapter qsys_top.qsys 584
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_5|a10_hps_f2sdram2_data_rd_rsp_width_adapter qsys_top.qsys 585
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_5|a10_hps_f2sdram2_data_wr_cmd_width_adapter qsys_top.qsys 586
Intel Corporation altera_merlin_width_adapter 18.1 N/A N/A soc_inst|mm_interconnect_5|a10_hps_f2sdram2_data_wr_rsp_width_adapter qsys_top.qsys 587
Intel Corporation altera_mm_interconnect 18.1 N/A N/A soc_inst|dp_0|mm_interconnect_0 subsys_dp.qsys 588
Intel Corporation altera_mm_interconnect 18.1 N/A N/A soc_inst|mm_interconnect_0 qsys_top.qsys 589
Intel Corporation altera_mm_interconnect 18.1 N/A N/A soc_inst|mm_interconnect_1 qsys_top.qsys 590
Intel Corporation altera_mm_interconnect 18.1 N/A N/A soc_inst|mm_interconnect_2 qsys_top.qsys 591
Intel Corporation altera_mm_interconnect 18.1 N/A N/A soc_inst|mm_interconnect_3 qsys_top.qsys 592
Intel Corporation altera_mm_interconnect 18.1 N/A N/A soc_inst|mm_interconnect_4 qsys_top.qsys 593
Intel Corporation altera_mm_interconnect 18.1 N/A N/A soc_inst|mm_interconnect_5 qsys_top.qsys 594
Intel Corporation altera_nios2_gen2 18.1 N/A N/A soc_inst|dp_0|cpu ip/subsys_dp/cpu.ip 595
Intel Corporation altera_nios2_gen2_unit 18.1 N/A N/A soc_inst|dp_0|cpu|altera_nios2_gen2_inst|cpu ip/subsys_dp/cpu.ip 596
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|dp_0|rst_controller qsys_top.qsys 597
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|dp_0|rst_controller_001 qsys_top.qsys 598
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|dp_0|rst_controller_002 qsys_top.qsys 599
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|rst_controller qsys_top.qsys 600
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|rst_controller qsys_top.qsys 601
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|rst_controller qsys_top.qsys 602
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|rst_controller qsys_top.qsys 603
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|rst_controller_001 qsys_top.qsys 604
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|rst_controller_002 qsys_top.qsys 605
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|rst_controller_003 qsys_top.qsys 606
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|rst_controller_004 qsys_top.qsys 607
Intel Corporation altera_reset_controller 18.1 N/A N/A soc_inst|rst_controller_005 qsys_top.qsys 608
Intel Corporation altera_signaltap_agent 18.1 N/A N/A auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|auto_signaltap_auto_signaltap_0 qdb/.t/5f51c95d63b4.tmp/.temp/sld_fabrics/ipgen/alt_sld_fab_0/alt_sld_fab_0.ip 609
Intel Corporation altera_xcvr_fpll_a10 18.1 N/A N/A soc_inst|dp_0|fpll_0 ip/subsys_dp/fpll_0.ip 610
Intel Corporation altera_xcvr_native_a10 18.1 N/A N/A soc_inst|dp_0|a10_xcvr ip/subsys_dp/a10_xcvr.ip 611
Intel Corporation altera_xcvr_reset_control 18.1 N/A N/A soc_inst|dp_0|dp_xcvr_ctrl ip/subsys_dp/dp_xcvr_ctrl.ip 612
Intel Corporation channel_adapter 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|b2p_adapter ip/qsys_top/f2sdram2_m.ip 613
Intel Corporation channel_adapter 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|p2b_adapter ip/qsys_top/f2sdram2_m.ip 614
Intel Corporation channel_adapter 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|b2p_adapter ip/qsys_top/fpga_m.ip 615
Intel Corporation channel_adapter 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|p2b_adapter ip/qsys_top/fpga_m.ip 616
Intel Corporation channel_adapter 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|b2p_adapter ip/qsys_top/hps_m.ip 617
Intel Corporation channel_adapter 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|p2b_adapter ip/qsys_top/hps_m.ip 618
Intel Corporation interrupt_latency_counter 18.1 N/A N/A soc_inst|ilc ip/qsys_top/ILC.ip 619
Intel Corporation QsysPrimePro 18.1 N/A N/A soc_inst|clk_100 ip/qsys_top/clk_100.ip 620
Intel Corporation QsysPrimePro 18.1 N/A N/A soc_inst|clock_bridge_0 ip/qsys_top/clock_bridge_0.ip 621
Intel Corporation QsysPrimePro 18.1 N/A N/A soc_inst|dp_0|clk_16 ip/subsys_dp/clk_16.ip 622
Intel Corporation QsysPrimePro 18.1 N/A N/A soc_inst|dp_0|clk_vip ip/subsys_dp/clk_vip.ip 623
Intel Corporation QsysPrimePro 18.1 N/A N/A soc_inst|dp_0|dp_clk_100 ip/subsys_dp/dp_clk_100.ip 624
Intel Corporation QsysPrimePro 18.1 N/A N/A soc_inst|dp_0|dp_rst_bdg ip/subsys_dp/dp_rst_bdg.ip 625
Intel Corporation QsysPrimePro 18.1 N/A N/A soc_inst|rst_bdg ip/qsys_top/rst_bdg.ip 626
Intel Corporation QsysPrimePro 18.1 N/A N/A soc_inst|rst_in ip/qsys_top/rst_in.ip 627
Intel Corporation timing_adapter 18.1 N/A N/A soc_inst|dp_0|avalon_st_adapter|timing_adapter_0 subsys_dp.qsys 628
Intel Corporation timing_adapter 18.1 N/A N/A soc_inst|f2sdram2_m|altera_jtag_avalon_master_inst|timing_adt ip/qsys_top/f2sdram2_m.ip 629
Intel Corporation timing_adapter 18.1 N/A N/A soc_inst|fpga_m|altera_jtag_avalon_master_inst|timing_adt ip/qsys_top/fpga_m.ip 630
Intel Corporation timing_adapter 18.1 N/A N/A soc_inst|hps_m|altera_jtag_avalon_master_inst|timing_adt ip/qsys_top/hps_m.ip 631
JET60200
had anyone met similar problem as this?  Thanks a lot
