- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I am attempting to run a simulation with design components from QSYS.
I am running the msim_setup.tcl script provided by QSYS and am getting the following error message... # vsim -t ps -L work -L work_lib -L error_adapter_0 -L altera_epcq_controller_core -L altera_asmi_parallel -L rsp_mux -L cmd_mux -L cmd_demux -L router_001 -L router -L avalon_st_adapter -L crosser -L rsp_mux_002 -L rsp_mux_001 -L rsp_demux_011 -L rsp_demux_009 -L rsp_demux_005 -L rsp_demux_004 -L rsp_demux_002 -L rsp_demux -L cmd_mux_002 -L cmd_demux_002 -L cmd_demux_001 -L epcq_controller_0_avl_mem_burst_adapter -L nios2_qsys_data_master_limiter -L router_014 -L router_007 -L router_005 -L router_003 -L router_002 -L avalon_internal_bram_interface_avalon_slave_agent -L nios2_qsys_data_master_agent -L avalon_internal_bram_interface_avalon_slave_translator -L nios2_qsys_data_master_translator -L remote_update_controller -L remote_update_core -L cpu -L dll0 -L oct0 -L c0 -L s0 -L p0 -L pll0 -L p2b_adapter -L b2p_adapter -L transacto -L p2b -L b2p -L fifo -L timing_adt -L jtag_phy_embedded_in_jtag_master -L rst_controller -L irq_synchronizer -L irq_mapper -L mm_interconnect_1 -L mm_interconnect_0 -L sysid_qsys -L sysclk_timer -L remote_update_0 -L onchip_mem -L nios2_qsys -L mem_if_lpddr2_emif -L mddr_to_mm_bridge_0 -L jtag_to_avalon_master -L hw_git_hash -L ext_int -L epcq_controller_0 -L avalon_internal_bram_interface -L avalon_external_interface_0 -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver C5G_QSYS # Start time: 15:55:58 on Jun 21,2018 # ** Note: (vsim-3812) Design is being optimized... # ** Error: C:/bin/altera/17.0.1/quartus/eda/sim_lib/mentor/cyclonev_atoms_ncrypt.v(38): in protected region Anyone have an idea on what is causing this? Thanks! Mikeコピーされたリンク
7 返答(返信)
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
As it is happening after the note saying that optimization has started, have you tried running it with optimization turned off?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Here is the result from running with -novopt....
# vsim -novopt -t ps -L work -L work_lib -L error_adapter_0 -L altera_epcq_controller_core -L altera_asmi_parallel -L rsp_mux -L cmd_mux -L cmd_demux -L router_001 -L router -L avalon_st_adapter -L crosser -L rsp_mux_002 -L rsp_mux_001 -L rsp_demux_011 -L rsp_demux_009 -L rsp_demux_005 -L rsp_demux_004 -L rsp_demux_002 -L rsp_demux -L cmd_mux_002 -L cmd_demux_002 -L cmd_demux_001 -L epcq_controller_0_avl_mem_burst_adapter -L nios2_qsys_data_master_limiter -L router_014 -L router_007 -L router_005 -L router_003 -L router_002 -L avalon_internal_bram_interface_avalon_slave_agent -L nios2_qsys_data_master_agent -L avalon_internal_bram_interface_avalon_slave_translator -L nios2_qsys_data_master_translator -L remote_update_controller -L remote_update_core -L cpu -L dll0 -L oct0 -L c0 -L s0 -L p0 -L pll0 -L p2b_adapter -L b2p_adapter -L transacto -L p2b -L b2p -L fifo -L timing_adt -L jtag_phy_embedded_in_jtag_master -L rst_controller -L irq_synchronizer -L irq_mapper -L mm_interconnect_1 -L mm_interconnect_0 -L sysid_qsys -L sysclk_timer -L remote_update_0 -L onchip_mem -L nios2_qsys -L mem_if_lpddr2_emif -L mddr_to_mm_bridge_0 -L jtag_to_avalon_master -L hw_git_hash -L ext_int -L epcq_controller_0 -L avalon_internal_bram_interface -L avalon_external_interface_0 -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver C5G_QSYS # Start time: 15:55:58 on Jun 21,2018 # ** Error (suppressible): (vsim-12110) All optimizations are disabled because the -novopt option is in effect. This will cause your simulation to run very slowly. If you are using this switch to preserve visibility for Debug or PLI features, please see the User's Manual section on Preserving Object Visibility with vopt. -novopt option is now deprecated and will be removed in future releases. # Error loading design # Error: Error loading design # Pausing macro execution Note that I am simply attempting to run the msim_setup.tcl generated by QSYS.- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
That's an error with turning off vopt now. Try running it again with -suppress 12110 to suppress that error.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
After using the suppress option, the simulation gets to this and fails....
# Loading altera_mf_ver.altera_std_synchronizer_bundle # ** Error: (vsim-3033) Instantiation of '<protected><protected><protected><protected><protected><protected>' failed. The design unit was not found. # Time: 0 ps Iteration: 0 Protected: /C5G_QSYS/epcq_controller_0/asmi_parallel_inst/altera_asmi_parallel/sd4/inst/<protected> File: C:/bin/altera/17.0.1/quartus/eda/sim_lib/mentor/cyclonev_atoms_ncrypt.v Line: UNKNOWN- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I've got same error from Questa Sim. Could you explain the solution one more time?
Best Regards.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Wow... That is not a helpful error message...
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
--- Quote Start --- That's an error with turning off vopt now. Try running it again with -suppress 12110 to suppress that error. --- Quote End --- Thanks i had# ** Error (suppressible): (vsim-12110) message and the -suppress 12110 seemed to solve it
