i've got an error trying to use fixed_float_types_c.vhdl and fixed_pkg_c error (10481): vhdl use clause error at producten.vhd(3): design library "work" does not contain primary unit "fixed_package"error (10800): vhdl error at producten.vhd(3): selected name in use clause is not an expanded name
Seems i'm not configuring properly the libraries or the access to them, can anyone help me? Alfonso Included the error files and both libraries to be included
Apparently you didn't include the package files in your project.
Please post questions like these in the appropriate location, this section is for *Forum Website* topics...
--- Quote Start --- Give me a forum and i'll provide you a reason why shouldn't be posted on these links, none of this links relates to code, please made your site more clear. --- Quote End --- Admin: I moved your post to the appropriate section.
Could you give the script you are using to compile your project?
You need to compile your two fixed_*.vhd files first and ensure they are in the work libraby.
