am new to model sim when am do simulation am getting error loading design please give solution for this
This could be due to the module name and the instance name are the same. Example:
module counter_tb;
reg clk, reset, enable;
wire [3:0] count;
counter_tb U0 (
.clk (clk),
.reset (reset),
.enable (enable),
.count (count)
endmodule
Try rename one of them (counter_tb) into a different name.
By sharing your code, then I can further debug and provide a better answer.
p.s. Don’t forget to Reply, and Select the Best Answer. :)
