17267 Discussions
Error while compiling encrypted files
agenor_micro
Hello Guys! I'm in the following situation:
I'm using:
Quartus version: 20.1.0.177-0.46w
QuestaSim Version: 2021.3_2
stratix10
I'm compiling some files but when it arrives in an encrypted file, I have the following error:
**Error:: file(line) (vlog - 2163) Macro `<protected> is undefined
The command I'm using is vlog -sv <file_path> -L <libs> -work <libs>
The same IP is being compiled in another machine, with a different Quartus and Questa configuration, so I believe the problem is related to the versions of the tools.
When I open the file I have the following information:
encrypt_agent = "Model Technology", encrypt_agent_info = "10.4d"
I'm trying to generate the same file with my QuestaSim version as the encrypt_agent, but I don't know how.  Does someone know how to do that? Does someone know a better solution for this?
Sorry for being so generic, If someone needs more info about it please, let me know.
hareesh
Hi agenor_micro
Check the file that contains the definitions of your macros must be included in the same directory of the working project or not. if it's not include into same prj directory.
agenor_micro
Hello there! Thanks a lot for the reply.
This encrypted file is an automatically generated file. Inside Quartus_ip or in the branch, we do not have any macro files (For this IP).
As I said previously, it is compiled locally, and we also don't have such macro files locally.
hareesh
Hi @agenor_micro,
Can you please share those files?
hareesh
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
