17255 Discussions
Error while creating a project using Nios II Software Build Tools for Eclipse
I am running quartus2 and nios2eds in windows.
i was unable to Create a New Nios II Application and BSP from Template.
the error was
unable to create project
Reason:
Failed to execute: ./create-this-app --no-make
chmod: changing permissions of `.': Permission denied
chmod: changing permissions of `./create-this-app': Permission denied
some one help me :confused:
--- Quote Start ---
the error was
Reason:
--- Quote End ---
I have the same problem. I'm using Quartus II web edition 10.0sp1 and Nios II Eclipse suite 10.0sp1
LigasN
I had this error with output like:
SEVERE: .entry section mapping not created because reset memory region
not located at base address 0xffffffffffffffff.
then I checked:
https://embdev.net/topic/248933
Had the same problem, sovled it by :
- in QSYS->System Contents , right click your Nios cpu -> Edit...
- in the tab "Core NiosII", check if "reset vector memory" points to a
memory module and not e.g. jtag etc.
- same with "exception vector memory"
- after correction : QSYS->Generation->Generate
 And finally, I've set the proper Reset Vector Memory (on my RAM.s1 connected to NIOSII) and Exception Vector the same way. I had no "Core NiosII" tab in 18.1 version.
I have the same problem . The appeared problem is :
Reason:
Failed to execute: ./create-this-bsp -- cpu name cpu_0 --no-make
Kindly advise.
Your prompt reply is highly appreciated
--- Quote Start ---
Reason:
Kindly advise.
--- Quote End ---
Use "Run As Administrator" command for Nios II Software Build Tools for Eclipse tool (i.e. right-click the Nios II Software Build Tools for Eclipse icon and select Run As Administrator).
Jari
Thank you. I tried it but it is still not working
Great!Thank you...
Thank you very much!
--- Quote Start ---
--- Quote End ---
Try sharing the project folders with everyone. I'm using Windows7 so I right-click on the top level project folder and select Sharing/Homegroup(Read/Write). Make sure the sharing caries down through the sub-folders.
sathvik
I have the same problem .Try it .Thank you very much.
I had the same issue when I tried to create "Hello world" project. I ran the eclipse as Administrator then it worked. Thanks a lot Jari..
-Vijay
