Errors in vhdl code
Hi.
i am compiling a vhdl file and getting some errors regrading packages
following is the error...
Error (10481): VHDL Use Clause error at output_fifo.vhd(13): design library "work" does not contain primary unit "Input_portx8_package"
can any one pls help me.......
Yes
The error is that you have not compiled the Input_portx8_package, but you are trying to use it elsewhere.
hi
work directory contains a file in .cat extension and it is not opening
The work directory will just be the location of the compiled code, not the source. You need to find the source VHD file.
