Hi.
i am compiling a vhdl file and getting some errors regrading packages following is the error... Error (10481): VHDL Use Clause error at output_fifo.vhd(13): design library "work" does not contain primary unit "Input_portx8_package" can any one pls help me.......Link Copied
Yes
The error is that you have not compiled the Input_portx8_package, but you are trying to use it elsewhere.- Mark as New
hi
work directory contains a file in .cat extension and it is not opening- Mark as New
The work directory will just be the location of the compiled code, not the source. You need to find the source VHD file.
